Old 09-23-2014, 11:04 PM   #1
Auctioneerhere
Spare Parts 64-66 4x4 Build
Ok, I am going to need some advice in the next few weeks.
I am starting a project from my spare parts collection. I have a 64-66 4x4 frame & a 2005 6.0 w/ 5 speed from a 2wd as a base.
The current plan is to set the 6.0 & nv 4500 trans in the 64 frame & use the divorced case.
I was planning to ditch the stock front end update it with a Dana 44 or perhaps a Dana 60.
I have several parts trucks, so I am really not to keen on buying anything big vs. using what I have.
Here is my last project.
Auctioneerhere is offline   Reply With Quote
Old 09-24-2014, 12:44 AM   #2
Captainfab
60-66 Nut
Re: Spare Parts 64-66 4x4 Build
Sounds like you have a good build planned. That looks like a fairly decent truck to start with.
Old 09-24-2014, 09:22 AM   #3
Auctioneerhere
The one above was pretty good to start with, the cab floors were rusted due to carpet issues. It is a dedicated puller. I have no plans to do much else to it other than smooth up the fenders some day.
Old 09-24-2014, 10:42 AM   #4
TJ's Chevy
TJ's Chevy's Avatar
Looks like it'll be a cool ride! I'm in.
Old 09-24-2014, 12:28 PM   #5
61K10
61K10's Avatar
this build will be interesting.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 09-24-2014, 11:20 PM   #6
Auctioneerhere
Here is what I am starting with. I am not sure exactly what year this frame is it had a 64-66 Chevy cab & bed on it.
I need to figure out what engine cross member to use with it. I am going to try a 4x4 engine cradle from a newer Chevrolet 4x4 78 - or newer than that.
I plan to use the ls conversion mounts to use the older style clamshell mounts.
Old 09-24-2014, 11:58 PM   #7
Captainfab
60-66 Nut
Don't know if it matters but that frame is a '60-'62.
Old 09-25-2014, 10:11 AM   #8
Auctioneerhere
I did not know that, but I suspected it was not a 64-66. I'm going to use it anyhow as I don't have another 4x4 frame at this time.
Thanks.
Old 09-30-2014, 09:25 PM   #9
Auctioneerhere
Well here is my transplant. I actually have the cab off at this point going to pull the engine & trans tomorrow. Kinda curious at this point to get it hovering above the frame to see how short the first drive shaft will be.
Old 10-12-2014, 07:34 PM   #10
Auctioneerhere
Well the 6.0 is now hovering above the 60-62 frame. At first I thought I might be able to mock up the original 2005 mounts to the older frame, but it seems like it would be more trouble than it would be worth.
I am going to order up some conversion plates for the older clam shell mounts. & next step is to measure a 73-87 frame for a possible donor cross member. The trans mount is going to be simple.
I had the stock 2005 Truck exhaust manifolds on, but at this point they look they wont fit at all. I ditched the ac for now & I am going to take off the power steering pump for the engine mock up.
