![]() Join Date: Sep 2009
Need Help Locating A few Parts
Hey All,
I finally got my 97 Yukon back from the body shop and it turned out great. I am now in the process of fixing some stuff Ive been putting off for a while, on the list is brake lines and fuel lines. I worked on it quite a bit this weekend, got it torn down, and starting to go back together. I started with installing the fuel lines, come to find out the PO had cross threaded the pressure line from the engine to the fuel filter. I have the fuel lines from GM, but now Im stuck. Im missing the pressure and return line from the TB to the filter. Im also missing the pressure line behind the filter to the rear line set. These are the part numbers I have and I was wondering if anyone could help me locate these, or tell me if there is a place that deals with NOS stuff for this style truck. Part Numbers: 15722273 This is the Hard Line From the Back of The Filter to the Rear Line 15719590 Pressure or Return Line from TB 15719573 Pressure or Return Line from TB Thanks for the help Sarge
1997 GMC Yukon Western Mid Weight Plow ![]() |
Re: Need Help Locating A few Parts
No One.... Looks like a road flare and a 5 gallon gas can will fix it for sure.
Sarge
Spear and magic helmet!
This is no help, but when I was checking youtube videos for replacing fuel pumps on Tahoes, the guy said to be careful with the fuel lines because no one makes them anymore.
I really hope for your sake that's not the case. |
If you feel confident with your part numbers, put them in google. Plenty of sources pop up many with same day shipping.
I did google it several times and they all come up not available. I did get in touch with Classic tube and they are able to reproduce the hard line, but I still cant find the pressure and return line from the back of the fuel rail to the front part of the fuel filter and the front section of the return hard line.
Thanks for the help. Sarge
Look at Ebay item #390417722469 is this what you are looking for? Hope it is
Tim- Bensalem PA |
| Bookmarks |
