Old 10-13-2014, 09:24 PM   #1
Ziegelsteinfaust
K20 sway bar
Is it a bad idea to drive regularly with out a front sway bar on a K20?
Or does the solid axle kind of act like one enough for cruising around.
Ziegelsteinfaust is offline   Reply With Quote
Old 10-13-2014, 10:34 PM   #2
beardface
beardface's Avatar
Re: K20 sway bar
4wd trucks didn't come with sway bars until 1973. So unless you're planning on exploring the limits of your truck's handling you should be fine.
Leon
'68 K20 fleetside, 400sb/sm465/np205, 4" lift, 32" tires.
beardface is offline   Reply With Quote
Old 10-13-2014, 10:53 PM   #3
Redcap
Re: K20 sway bar
Not at all. I run my K25 without one all the time and actually don't like how it feels with it hooked up, despite the fact that I have ORD swaybar disconnects.
'77 K35 - 454, SM465/NP205, 4.56 D60/14bFF
Redcap is offline   Reply With Quote
Old 10-15-2014, 12:36 PM   #4
burnin oil
Re: K20 sway bar
I added one to my 72 K20. It did wonders for it on the street. The springs dont move all that well off road so I consider a good upgrade over all. Still no problems running around in the woods. Mine was a donated by a 80ish blazer.
burnin oil is offline   Reply With Quote
