Old 10-12-2014, 09:20 PM   #1
Kinze
K30 center caps
I am going to buy aluminum wheels for a K30 SRW (single rear wheel) but I cannot find any info on the correct size center caps, I don't want them sticking out any farther then needed, the fronts will be open for the Dana 60. What is the correct size and length? I will be using Alcoa brand caps. Thanks!
Kinze is offline   Reply With Quote
Old 10-13-2014, 09:29 PM   #2
Kinze
Re: K30 center caps
Old 10-14-2014, 07:25 AM   #3
cadillac_al
Re: K30 center caps
I always left mine open front and back. Too cheap to buy some caps I suppose.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 10-14-2014, 11:44 AM   #4
dieseldawg142
dieseldawg142's Avatar
Re: K30 center caps
the center caps on my K30 are 4 5/8". length?-personal preference...
dieseldawg142 is offline   Reply With Quote
Old 10-14-2014, 12:00 PM   #5
Kinze
Re: K30 center caps
Thank you! I just need to make sure I order ones that will be long enough without getting ones that are any longer then need be.
Old 10-14-2014, 07:56 PM   #6
Axle
Axle's Avatar
Re: K30 center caps
That size wheel are you ordering? The backspace, combined with the width will determin how much distance from the hub face to the edge of the wheel.ie: 15x6" wheel, 3" backspace, you end up with ~2 3/4" before the cap sticks beyond the edge of the wheel. Get a 15x10" wheel with the same 3" back space and you have almost 7" of space to stick a cap.
Have you got a full or semi-floater? Get a cap long enough to clear the axle. Otherwise, just get the shortest one they have if you don't like tall center caps.
Alex.
Axle is offline   Reply With Quote
Old 10-14-2014, 08:04 PM   #7
Kinze
Re: K30 center caps
Alcoa Classic Single Wheel 16" x 7" 8-6.5" bolt circle, 5.155" hub bore, 4.290" backspace inches, 0.250" offset
Does that help? Going on 4x4 K30 so need the open front caps and I would think they will need to be pretty long as the lockouts on the Dana 60 stick out a good ways.
Rear is the standard Corp 14 bolt full floater that came in all the 3/4 and 1tons for years.
Thanks for any help, never knew finding center caps would be so hard!
Old 10-15-2014, 09:05 PM   #8
farmall
farmall's Avatar
Re: K30 center caps
Contact
http://www.southwestwheel.com/store/...aspx?pagenum=1
1955 GMC 250 8 Flatbed
1971 C30 157" 350 4spd 10' Flatbed
81 GMC K30 CnC 9' Flatbed 454 T400
89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958
71 LT1 Convertible, 72 Coupe
69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2
farmall is offline   Reply With Quote
Old 10-15-2014, 09:22 PM   #9
Kinze
Re: K30 center caps
I regret ordering my wheels from Southwest wheel, they have no idea what they are doing! I will pay more to avoid them in the feature!
They have no idea what lug nuts our trucks take OR what center caps fit, what a joke.
I had to tell them what their screw up was and what lugs I needed as well as what model center caps to order. I talked to both Jeff and Derek there. Now I get to send them back and wait for them to send me the correct parts...
Old 10-18-2014, 10:04 PM   #10
Kinze
Re: K30 center caps
Are 4in. deep center caps going to fit or will I need deeper ones?
Old 10-19-2014, 12:01 AM   #11
dieseldawg142
Re: K30 center caps
four inch will be fine. mine are 4 5/8's o.d. & 4" long (14b ff)
