Old 10-13-2014, 09:44 PM   #1
badpeanut
Not a bad nut after all..
badpeanut's Avatar
WTB: Speedo Adapter Box w/1.300 Ratio
I'm looking for a Steward Warner speedometer adapter box similar to the one in the picture with a 1.300 ratio. The ratio is stamped on the lower pad in the picture.
'05 Chevy 2500HD 4x4
'72 GMC LWB 4x2 driver
'72 Chevy LWB 4x4 plow truck
'71 Blazer 4x4 driver
'70 GMC LWB trailer
badpeanut is offline   Reply With Quote
Old 10-14-2014, 07:54 AM   #2
jasons
not enough hours in the day
jasons's Avatar
Re: WTB: Speedo Adapter Box w/1.300 Ratio
If you don't have any luck finding a original one you can get new adapters here that look the same.
http://www.transmissioncenter.net/sp...n_______va.htm
65 K-10 Short Step
68 C-50
70 K-5
85 K-10
& piles of spare parts
jasons is offline   Reply With Quote
Old 10-14-2014, 08:17 AM   #3
paul mora
I have one not sure what ratio. I will be home Thursday I can check it if you still need one
Pulatoy
paul mora is offline   Reply With Quote
Old 10-14-2014, 08:44 AM   #4
nlped
nlped's Avatar
I have a couple of them at the house. I'll try and remember to look this evening.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 10-14-2014, 11:25 AM   #5
Ironhorse
Ironhorse's Avatar
Second on the www.transmissioncenter.net comment from jasons. I needed to correct my speedometer on my '71 4x4 after swapping from stick sm465/np205 to a 350TH/np205 auto. Plug n play, no muss, no fuss. Look for speedometer ratio adapter. Speedometer is dead on with my Garmin GPS now.
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is offline   Reply With Quote
Old 10-15-2014, 12:44 AM   #6
badpeanut
badpeanut's Avatar
I'd appreciate it if you folks could look for any with a 1.300 ratio.
'70 GMC LWB trailer
