K20 sway bar
Is it a bad idea to drive regularly with out a front sway bar on a K20?
Or does the solid axle kind of act like one enough for cruising around. |
Re: K20 sway bar
4wd trucks didn't come with sway bars until 1973. So unless you're planning on exploring the limits of your truck's handling you should be fine.
Leon '68 K20 fleetside, 400sb/sm465/np205, 4" lift, 32" tires. |
Re: K20 sway bar
Not at all. I run my K25 without one all the time and actually don't like how it feels with it hooked up, despite the fact that I have ORD swaybar disconnects.
'77 K35 - 454, SM465/NP205, 4.56 D60/14bFF |
Re: K20 sway bar
I added one to my 72 K20. It did wonders for it on the street. The springs dont move all that well off road so I consider a good upgrade over all. Still no problems running around in the woods. Mine was a donated by a 80ish blazer.
