Old 10-15-2014, 12:50 PM   #1
no1udknow
no1udknow's Avatar
wiring harness options....
So I took the 68 out for a little road test yesterday to assess some carb adjustment/timing issues, and after driving around the block, I pulled in to the drive and popped the hood. I noticed first that I was leaking oil from the drivers side valve cover on to the headers... no biggie, then I noticed smoke lightly rising from the wiring harness running along the groove in the firewall. I quickly shut the truck off and had grabbed the harness, and sure enough, it was pretty hot. It appears to be the original harness with a few cut and pastes here and there. I'm thinking I either want to buy a new harness that has been beefed up a bit, or build my own. I am wondering who has good replacement harnesses. I am not one to toot my own horn, but I am a bit of an electrical guru, I spent many years building, testing, and repairing slot machines and I build custom bikes and their wire harnesses from scratch, so I am not scared to build a harness.... just lazy
Built not bought!
My dad always tried to convince me HEI was pointless!
Welding is a lot like sex, you don't have to be great with the rod as long as you thoroughly prep the surface and your good at grinding
My build : 68 C10 Short Bed Conversion
no1udknow is offline   Reply With Quote
Old 10-15-2014, 03:42 PM   #2
jmorri34
jmorri34's Avatar
Re: wiring harness options....
That depends on you and if you really want to do it and what the costs are for materials which I am sure would be cheaper than buying one. So it comes down to want lol, do you wanna go to the trouble or buy it. I couldn't build my own and bought the American Autowire setup and I loved it, nice and easy , came with instructions, and all you need and more to build it. (minus the crimpers) So money/work vs want/ease. just my opinion and I am sure some others will chime in as well
1969 cst prostreet
http://67-72chevytrucks.com/vboard/s...d.php?t=568661
jmorri34 is offline   Reply With Quote
Old 10-15-2014, 04:02 PM   #3
leftybass209
leftybass209's Avatar
I think you answered your own question by being an electrician yourself. If you replace the harness with a plug and play unit, you have a slightly better than new 60 year old harness. The stock harness works great, and i replaced my engine harness with an M&H harness designed for HEI. If you do your own with say a painless kit, you get the added benefit of running the wires how you want, you get blade fuses, and you can add any accessories you may want.
leftybass209 is offline   Reply With Quote
Old 10-15-2014, 05:39 PM   #4
ujsf01
ujsf01's Avatar
I own a small business that specializes in electrical systems on classics and customs, and for my money, I use American Autowire exclusively. They cost a little more, but it's because they come with everything you need to install them properly. I looked at using Painless, but they require too much splicing in on connectors and being an electrical guy yourself, you know resistance is the enemy of electrical systems. That's my two cents worth.
Steve McMillen
ASE and GM certified Master Technician
25 years+ experience
No, I do not know it all, that's why I attend tons of training.
ujsf01 is offline   Reply With Quote
Old 10-15-2014, 05:45 PM   #5
Xeen
Xeen's Avatar
Here's one option Speedway motors 12 circuit wiring harness.
http://www.speedwaymotors.com/Speedw...ness,2352.html
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 10-15-2014, 09:06 PM   #6
michael bustamante
michael bustamante's Avatar
Theres a guy in the parts section selling 68 wiring harness.
1967custom
michael bustamante is offline   Reply With Quote
Old 10-15-2014, 09:15 PM   #7
hdff
hdff's Avatar
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach
"Wanda"
Don't argue with idiots, People watching may not be able to tell the difference...
There's someone in my head........But it's not me......
cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394
hdff is offline   Reply With Quote
Old 10-15-2014, 10:22 PM   #8
truckdude239
truckdude239's Avatar
American auto wire all the way
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
