Re: Brake Repair: Slotted/Drilled Rotors worth the cost?
I guess my point was the drilled/slotted rotors are always advertised as an improvement but seldom is there testing to prove the benefits.
#2 | |
i'm with 86c20, just HOW big are these hills? when we go camping we're loaded at 15 thousand & i have the "smasher", a 10% grade hill for 9 or 10 miles just down the road from me & i've never had the brakes on my crew "cook" or fade, use your gears to keep your speed under control. i did the brakes on my crew 5yrs ago, everything new, lines, calipers, rotors, drums, springs, etc, front disc, rear drum, stock set-up but used "premium" parts. stops pretty impressive for a 4 ton truck. |
It'd be alot cooler if you did
I agree, and usually they just look out of place. Raybestous sells some nice quality slotted/drilled rotors through rockauto. Best bang for the buck if you're going for the "look".
