Old 10-16-2014, 07:20 PM   #1
Harpie
Harpie's Avatar
Fan shroud question!
Ok I think I got this figured out but I know you guys can help me out. I swapped in a vortec 5.7 in my 71 and am getting everything ready to fire it for the first time in the truck. Dropped my radiator in (4row) and my small block factory fan shroud is not going to work. The fan is just a little big and I think if it had of fit will be past the fan. So if I'm reading everything correctly is the big block shroud thinner and possibly have a bigger opening for the fan? Hope that makes sense lol thanks for any advice in advance.
Harpie is offline   Reply With Quote
Old 10-16-2014, 07:22 PM   #2
davepl
davepl's Avatar
Re: Fan shroud question!
What's the size of the one you have?
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 10-16-2014, 07:27 PM   #3
Harpie
Harpie's Avatar
Fan looks to be 19in and that's right at the shroud opening size. Biggest issue is the thickness of the shroud.
Old 10-16-2014, 07:44 PM   #4
Lee H
Lee H's Avatar
There's lots of fans available in the 16-18 inch range, check out Derale. The AC fan shroud is a little over 1 inch deeper than a non-AC shroud.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 10-16-2014, 07:49 PM   #5
Harpie
Harpie's Avatar
Ok thank you I'll see about changing the fan.
Old 10-16-2014, 07:56 PM   #6
Undone
Thought it was the other way around. Non AC deeper?
Undone is offline   Reply With Quote
Old 10-16-2014, 08:31 PM   #7
FirstOwner69
FirstOwner69's Avatar
I agree. Factory small block non-A/C shroud is 3/4" to 7/8" deeper than the A/C shroud. Here's a pic of them back to back. The A/C shroud is on the right.
FirstOwner69 is offline   Reply With Quote
Old 10-16-2014, 08:54 PM   #8
FirstOwner69
What water pump are you running? Short, long or from the Vortec engine? Serpentine or V belts? Is the fan from the Vortec engine? If from the Vortec and serpentine, is the fan the right rotation?
Old 10-16-2014, 08:58 PM   #9
Harpie
Harpie's Avatar
It's the complete power plant motor and trans from donor vehicle. It has the factory serp setup and fan and pump.
Old 10-16-2014, 09:43 PM   #10
Lee H
Lee H's Avatar
I stand corrected.
Old 10-16-2014, 10:18 PM   #11
FirstOwner69
I tried searching the forum for "serpentine fan shroud" and got some results that may help. Give it a try and see what you think. Just check to be sure the thread applies to 67-72 trucks.
Old 10-16-2014, 10:30 PM   #12
Harpie
Harpie's Avatar
Ill didn't try that wording thanks I'll do that now.
Old 10-16-2014, 10:37 PM   #13
Harpie
Harpie's Avatar
Well that was what I needed looks like a BB shroud it is. Now to find a good deal on one. Thanks guys for the help!
