Old 10-16-2014, 06:31 PM   #1
MountainGoat1966
84 K10 acted like it hit a boulder and stopped rolling, but no boulder
I was driving home the other day after cutting firewood, was using 4x4 mode offroad, but had the transfer case in 2H with hubs still locked in on the decent road.
Going about 5 MPH since the road is real bad and I had a heavier than normal load.
All of a sudden, the truck made a clunk and stopped rolling, just like I had hit a boulder.
Put it in reverse and was able to move backwards.
Unlocked the hubs and I was able to continue driving forward.
I suspect the front pinion bearing, as it was rough and made noise when I installed a limited slip carrier about a month ago.
I was hoping it would have lasted longer.
Now, I will obviously need to replace the front pinion bearing, but don't want to deal with the crush sleeve crap.
I saw somewhere (but can't find it now) there is a solution that uses shims and is much easier to set the preload.
It's a stock 8.5" 10 bolt axle.
"Off the grid and on the seven day weekend plan"
"One person cannot know everything, but between all of us, there isn't much we don't know."
MountainGoat1966 is offline   Reply With Quote
Old 10-16-2014, 07:59 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: 84 K10 acted like it hit a boulder and stopped rolling, but no boulder
if you don't get sufficient replies here you may want to ask in the suspension part of the forum a lot of good 4wd gurus there
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 10-16-2014, 10:13 PM   #3
Hiluxxulih
Hiluxxulih's Avatar
Maybe a steering knuckle u joint .
Hiluxxulih is offline   Reply With Quote
