Where did you get your lift from?
I'm looking for a 4" lift on a 68 K20, i'll need all 4 leafs and anything else that comes with the kit would be a bonus. Who did you deal with and who did you find had the best deals? I've had a hard time finding 3/4 ton rear springs, lots of places only have 1/2 ton which I don't want.
Re: Where did you get your lift from?
*reason I need all 4 springs is because the rear springs are both cracked in two, right over the diff.
I ended up getting mine from SDTruckSprings.com. At the time, they had the best deal running for what I was looking for.
Talk to http://www.offroaddesign.com/ they don't have it listed but they can get a lot of stuff.
Off road Designs all the way! It may be a little more expensive but totally worth it! great products and great people
Jim 1972 K20 Cheyenne- 350/350/205 1972 K20 Cheyenne - 350/SM465/205 1971 K5 Blazer |
Alcan builds ORDs springs, it's a very nice spring. The reason I went to ORD is they have tons of experience our trucks and newer trucks. They actually test their product. I would go through ORD because you either give alcan your specs, you leave the decision to alcan and they can try their best, or you let ORD build a set that is made for your truck, so if you have a big block, or small Block, or any other modifications done the will consider that to build you the best possible spring pack for your truck.
