Old 10-17-2014, 09:35 PM   #1
LuvNLife
LuvNLife's Avatar
Fuel System Part - What's It's Correct Name & Where To Buy It?
I'm revamping the fuel system under my '87 GMC shortbed fleetside. The current setup is jury rigged so badly, it seems easier to just replace it.
The truck was EFI, but that's gone now in favor of a carb. The truck has twin fuel tanks, but only the passenger side is running. The former owner converted one side of the the dash tank switch into a kill switch, and we can't quite trace it all out. So, here's where I'm thinking of going.
I'd like to add a pair of low pressure, 30 GPH external electric fuel pumps, wire them both hot, then wire the grounds to twin rocker switches I'll put under the dash. I'll also install a pair of fuel gauges to go with them. That part is pretty straight forward. But, I need some type of "Y" junction to run the two fuel lines into, with one outlet to the carb. I have zero idea what that "Y" is called or where to find one.
Any thoughts or leads would really be appreciated.
Jerry
LuvNLife is offline   Reply With Quote
Old 10-17-2014, 09:54 PM   #2
Kenfuzed
Kenfuzed's Avatar
Re: Fuel System Part - What's It's Correct Name & Where To Buy It?
Just thinking your plan through, but if you run 2 pumps into a wye (Y) wouldn't fuel flow back into the other non-running side/tank as well? It seems fuel will simply take the path of least resistance unless you have a way to close the path to the unused side by way of a check valve.
Rather than wiring the pumps hot maybe a dual relay would work better. I saw this at Jegs.
http://www.jegs.com/i/JEGS-Performan...oductId=758615
1966 C10 Short Fleetside
1988 Sportster, 2008 Street Glide
Ken's 1966 C10 build "Red Ale"
Follow on Instgram: @cv_performance
https://instagram.com/cv_performance
Harley Performance Parts: CV Performance (Harley related)
Enjoying the ride!
Kenfuzed is offline   Reply With Quote
Old 10-18-2014, 07:41 AM   #3
tucsonjwt
I would favor just installing the stock system - it does not seem very complicated to me, but I am no mechanic. I did see a work around for a failed OEM dual tank set up that used a manual valve mounted on the outboard side of the floor pan next to the driver's seat. Fuel hoses from the two tanks ran to the manual valve and then to the fuel supply line.
I think the hard part of an OEM set up is getting the proper length and bends in the hard fuel lines. Others can post the wiring diagrams, and I think I have pics of the actual wiring installation on an older dual tank set up, if you want to see them. Rewiring from scratch should not be difficult. So, if your hard fuel lines are intact, I would still go with the OEM set up.
tucsonjwt is offline   Reply With Quote
