Old 10-18-2014, 10:07 AM   #401
62 Barnfind
62 Barnfind's Avatar
Re: 61K10 build
Truck looks great! Great idea for installing the hood.
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline   Reply With Quote
Old 10-18-2014, 11:45 AM   #402
argonaut
argonaut's Avatar
Re: 61K10 build
Truck looks amazing! And provides good motivation for slackers like me.
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 10-18-2014, 12:40 PM   #403
61K10
61K10's Avatar
Re: 61K10 build
Jason--you are young and have plenty of time, enjoy other things. on the t/f case you put new clevises (if that right name) I could not get it adjusted with them. couldn't get it to go into 2h. put my old ones on and got it to go into 2h. might have been just me. have to drain it as one of the rounds plates is leaking a bit. my pto is leaking a little also. and i hate oil leaks!
take care my friend----------kimble
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 10-20-2014, 10:25 AM   #404
chevy_man5
GMC's n H.D.'s too!
chevy_man5's Avatar
Re: 61K10 build
The truck looks amazing!! Great job!!
Jason
1960 GMC 4x4 Babe (the Blue Ox) - Build Thread
chevy_man5 is offline   Reply With Quote
Old 10-23-2014, 01:14 PM   #405
61K10
61K10's Avatar
Re: 61K10 build
well another problem with my fuel gauge--does not work, so i took out the cluster (pita) and put in another gauge that came with the tk. still no=workie. have a new sending unit and the old org one also. both test ok. So I'm putting new gauges, not stock. heres the gauges that i will put in the stock cluster. we will see if i can make these work and look some what stock.
1961 chevy K10
Old 10-24-2014, 10:13 AM   #406
argonaut
argonaut's Avatar
Re: 61K10 build
Is the sending unit well grounded?
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 10-24-2014, 11:50 AM   #407
MitchFloyd
MitchFloyd's Avatar
Re: 61K10 build
Is that the only guage not working? And if you are sure it's the guage and not any wiring issues, ie ground as Argonaut suggest, I could send you another guage. If you've already got those in the pic, tho, they look pretty nice upgrade.
'62 Chevy K10
MitchFloyd is offline   Reply With Quote
Old 10-24-2014, 02:10 PM   #408
61K10
61K10's Avatar
Re: 61K10 build
will see if i can make these work. two sending units Jason, new in the tk and one on the bench. wiring is new american auto wire as i had dash problems with the org wiring. the ground is good as is power to the gauge. tired of 50yr old junk.
I bought a gauge cluster on e-bay when i started. the speedo was set back to ooooo and it looks like new # were installed. when i drove the tk for the first time getting into 4g all of a sudden one big buzzing noise out of the speedo (has new speedo cable) so i put my org one back in but haven't driven the tk yet as my dash cluster is out.
this thing is spooky to drive lol. moves around a little (probably my used steering box) every time i try to save some $$$ it bite's me in the you know where lol.
1961 chevy K10
Old 10-24-2014, 03:42 PM   #409
argonaut
argonaut's Avatar
Re: 61K10 build
Are you going to retrofit the existing cluster with the new gauges behind the faceplate? Or are you making a new baseplate with all new surface mount gauges like these?
I do like the classic style of those new gauges.
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 10-25-2014, 01:32 PM   #410
61K10
61K10's Avatar
Re: 61K10 build
Jason--yes i am going to put them behind the face plate. I mocked one up with another gauge 2-1/8". took the bezel and glass off. will take a pic. I hope the new ones come apart easy.
1961 chevy K10
Old 10-25-2014, 01:45 PM   #411
argonaut
argonaut's Avatar
Re: 61K10 build
Very cool. The one thing I love about the original gauges is the big sweeping speedometer. I have swapped in a volt meter from a later model chevy. I I adapted the gauge faceplate to it and then modified the back of the cluster to make it fit. Anyway, my point is that it is doable.
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 10-25-2014, 03:18 PM   #412
padresag
Re: 61K10 build
did you rebearing your t/c by any chance?. those round plates sometimes wear through from end play from worn brgs and thrust washers. sometimes you don't see the little cut from the wear and it leaks from there
ron
padresag is offline   Reply With Quote
Old 10-26-2014, 01:36 PM   #413
61K10
61K10's Avatar
Re: 61K10 build
ron--not the org t/c. bought it from argonaut. it was not an org from his tk as the tag was from some tk shop and there are no # stamped on it. Jason re-gasketed and new seals. the leek was just a weep. seems like it has stopped? pto weeps some also. time will tell.
1961 chevy K10
Old 10-26-2014, 02:12 PM   #414
61K10
61K10's Avatar
Re: 61K10 build
couple of pics of my fuel gauge. volt gauge is coming from Ohio. the v-gauge in the left is no good, got it to work a couple of times then nothing. might get a clock to match my gauges later at $101.00 way later. I would like to replace all with new but too much $$$. the gauge in the batt window will be a new green face one
1961 chevy K10
Old 10-26-2014, 02:18 PM   #415
MitchFloyd
MitchFloyd's Avatar
Re: 61K10 build
That's perfect! Be sure to save the two old gauges though, just in case you ever go back & figure out why they didn't work.
Add the temp and oil pressure and it'll "look" normal. Most people won't know.
'62 Chevy K10
Old 11-03-2014, 03:55 PM   #416
61K10
61K10's Avatar
Re: 61K10 build
well got my gauge cluster back in, gas and volt gauges work. as usually another problem. rear end is shot. when i had it apart i readjusted the backlash that was way loose. It makes big noise now. removed d/s to t/f case--trans was quiet. put d/s back in and removed d/s to rear--t/f case was ok, a little noisy but that was expected. hooked d/s back to rear and put the rear on jack-stands. rear is very noisy on acceleration and d-acceleration. and yes no ring & pinion's in 3.90 avl. as the party goes on and the road never ends!
1961 chevy K10
Old 11-03-2014, 04:10 PM   #417
MitchFloyd
MitchFloyd's Avatar
Re: 61K10 build
Cluster looks good! Sorry to hear bout the ring & Pinion. Try a couple junk yards in your area. Those Eaton rear ends are all over the place here in Tx and Okla. Just have to take the cover off a couple to see which ones are good.
Got a question for you tho, since you just did everything. I'm putting a gauge cluster in my dash as well, but keeping the orig fuse box and wiring. Will the dash cluster harness with gauges plug into my orig harness? Thought , I'd ask before calling.
'62 Chevy K10
Old 11-03-2014, 05:48 PM   #418
RANDY COX
RANDY COX's Avatar
Re: 61K10 build
Kimble I hate to hear that after all the work you've done. I had to replace my rear yoke on mine and I just installed another one and just tightened it up pretty good...I was wondering about that crush sleeve. I haven't driven mine on the road since I got it 2 yrs ago... Other than when I tried it out when I bought it, it was very slow with 4:56's gears and 4 spd and the V-8 with a mild cam just didn't act like it had the power it should have had.
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 11-04-2014, 02:13 PM   #419
61K10
61K10's Avatar
Re: 61K10 build
Mitch--have maybe a line on one from an old friend i grew up with. Randy--my rear is 3.90 so a little more highway friendly. I had a feeling that is was gonna make noise. I hate to put in a 12 bolt--we will see i guess.
1961 chevy K10
Old 11-05-2014, 01:56 PM   #420
61K10
61K10's Avatar
Re: 61K10 build
Mitch--forgot to answer your question about the gauge cluster. the gauge wiring is a little different, can't remember all the details. you would need a new temp sending unit(???) and tubing from eng to manual oil gauge. I would not use the amp gauge myself. I know you can buy the gauge cluster wiring.
kimble
1961 chevy K10
Old 11-05-2014, 02:06 PM   #421
pimpston65
pimpston65's Avatar
Re: 61K10 build
sneeky dash cluster, i like it!!! updated with vintage look and shouldnt break the bank
pimpston65 is offline   Reply With Quote
Old 11-05-2014, 03:50 PM   #422
MitchFloyd
MitchFloyd's Avatar
Re: 61K10 build
Thanks Kimble. Hey, You never said if you opened the diff cover on your rear end or not. As long teeth on the ring & pinion are not worn, you might wanna check out the differential rebuild kit that Ecklers sells for the eaton diffs. It's listed as 1955 2nd series - 62 rebuild kit. Comes with all the needed bearings & races. Maybe its just a bearing going bad.
'62 Chevy K10
Old 11-05-2014, 03:57 PM   #423
MitchFloyd
MitchFloyd's Avatar
Re: 61K10 build
'62 Chevy K10
Old 11-06-2014, 12:57 PM   #424
61K10
61K10's Avatar
Re: 61K10 build
Mitch--I had the hole third member out of the housing as it was leaking,also to ck axle bearings (which were good as was the axles). the R&P had about .250 slop (loose) i readjusted the back lash to spec. so it was worn by being out of spec, and it's not the org one either. I thank the date was 1959. might just rebuild it with 3.38's till i come up with a good 3.90. the closes r&p for the ft dana44 3.31's which is stretching it a bit. probable never use 4wd anyway. going to fix all my leeks in the t/f case and figure out the R-end. I've built a few rear ends some years ago when i was Drag racing.
1961 chevy K10
Old 11-06-2014, 03:32 PM   #425
TJ's Chevy
TJ's Chevy's Avatar
Re: 61K10 build
That gauge cluster looks super! Yer truck is coming along nicely! You've done a job well done. Now you can help me with mine.
