01-19-2004, 10:09 PM | #1 |
electrical ?
when i apply the gas pedal in my truck my dash lights come on, my dad says it is a short, i am just wondering where to start looking for this so i can fix it.
thanks guys
Krazy Texan My Trucks are made with Wrenches not Chop Sticks 1967 GMC 3/4 ton "Johnny Cash" 1990 v1500 suburban 1967 Ford f100 Swb 4x4 "green bean" GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO Last edited by krazy_texan; 01-20-2004 at 07:56 PM. |
01-19-2004, 10:10 PM | #2 |
Formerly yellow72custom
Check for a bad ground.....i had to run a wire from the rear metal part of my insturment cluster to a clean ground on the dashboard to get it to work correctly.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
01-19-2004, 10:45 PM | #3 |
My son, my joy.
I'd start by checking around the throttle linkage for wires that may have been damaged by rubbing or pinching.
01-19-2004, 11:59 PM | #4 |
Assuming you mean when you apply the BRAKE pedal the dash lights come on, check the rear brake/tail light 1157 bulbs to be sure that one of them is not installed correctly.
1971 C10 swb stepside 350/700R4/3.73posi (retired as of 4/22/03) 1998 S10 short bed 2002 S10 Blazer 1942 Oldsmobile 1958 Massey Harris Pony 1951 Wife Killingworth, Connecticut May those who love us, love us, any of those who do not love us, may God turn their hearts. And if God is unable to turn their hearts, may he turn their ankles so we may know them by their limping. A man who works with his hands is a laborer; a man who works with his hands and his brain is a craftsman; but a man who works with his hands and his brain and his heart is an artist. |
01-20-2004, 12:07 AM | #5 |
its all about the +6 inches
I'll bet that one of the tail lights has the wrong bulb in there. An 1156 instead of an 1175.
Remove your tail light lenses and look at the bulbs real close. If there is only one filiment in the bulb, then you need to replace it. |
01-20-2004, 01:16 AM | #6 |
well one of my bulbs is out i am going to replace it after work tommarow could that be the problem
Krazy Texan My Trucks are made with Wrenches not Chop Sticks 1967 GMC 3/4 ton "Johnny Cash" 1990 v1500 suburban 1967 Ford f100 Swb 4x4 "green bean" GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO |
01-20-2004, 07:54 PM | #7 |
i replaced that bulb and still nothing, i tried grounding the dash and nothing I have now noticed also that when i apply the brake pedal not only do the dash lights come on but so does the left front side marker comes on and when i turn on the lights that side marker comes on but very dim, and after all this my blinkers wont work neither, and i put new flasher in today.
01-20-2004, 08:41 PM | #8 |
Not the nightly winner
sounds like a ground on one of your lites somewhere,or one of the front marker lites,just a thought
72C10SWB BLUE 350/350 86K10LWB BLUE 5.7 700r4 7.5' fisher plow 93S10XCAB4X4 BLUE 4.3 4L60e 69gmc c10 v8 3 on the tree yellow 72k10 swb 350 3 on the tree green 86k15 swb5.0L 4spd brown |
01-20-2004, 09:12 PM | #9 |
I also believe you're dealing with a classic grounding problem....I'd go around to all the light sockects and make sure the grounds are solid.... make sure there's good fresh metal where the ground screw is.... use sandpaper or emery cloth to create a good metal to metal connection at every ground point.
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA 72 Stepside Project |
01-20-2004, 11:23 PM | #10 |
Parking lights and brake lights are not on the same circuit. There is a meesed up wire or bulp 'leaking' electricity fromt eh brake light circuit into the parking light circuit.
