Tie Rod socket ball keeps on spinning...need help!
hey guys, so I just swapped out some springs and I have everything together but one of the tie rods keeps on spinning when I try to tighten the bolt. Anything I can do to hold the bolt from spinning so I can tighten the nut to it?
Thanks! |
Re: Tie Rod socket ball keeps on spinning...need help!
Put a jack under the A-arm near the ball joint and lift the pickup. This should keep it from spinning.
#3 | |
Cluster King
![]() Join Date: Nov 2012
That should hold enough pressure on it to be able to tighten the nut without the stud spinning. Good luck, Tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com I am also a dealer for Counterpart for gauge cluster parts only. Also see my facebook page, CG&C |
![]() Join Date: Aug 2008
You might also need to use an air impact to tighten it quickly.
![]() Join Date: Feb 2012
just squeeze it with large channel lock pliers and hit it with an impact
Have had this before. If you (you being me) or a P.O. used a hammer on the top of the castle nut to bust the tie rod loose it can cause one or more the legs on the castle nut to bend inwards and act as a really frigging good locking feature. Easiest option is to remove the nut and inspect for deformities. Run a tap thru castle nut, crank a proper sized bolt thru the nut or R2 the nut and/or tie rod end.... It may just be worn out...
![]() In the past I have creatively used a 10" C-clamp to mash the tie rod into the spindle and hold while turning the nut. Sounds OK to get it together. It will suck even more when you take it apart next time. Trust me, the temp fix will haunt you when you least expect it. Good luck. 88Ironduke
Retired USAF - No rockets, no mortars, no bad guys shooting...No stress!!! ![]() My Build Thread: Project 72' Green http://67-72chevytrucks.com/vboard/s...d.php?t=587932 |
