Build plans
So I bought the truck knowing that I planned to make a "hotrod" kinda truck with maybe the occasional touch of "kustom" here and there. This will be my daily driver, and around here you catch a lot of looks when you roll something like this on the daily. Virginia Beach is a relatively young city and fairly wealthy, so the cars on the streets are typically newer. I live where the elevation is flat and there are nothing but half way decent streets, so lowering it was not only a preference, but not going to be an issue. (aside from maybe the occasional flood) Hahah
So here are the plans and then Ill detail the parts I am using as well. *Static drop and keep it realistic. *Has to have a little bit of "rake" to keep the hotrod look and feel. *Disc brakes *5 speed *shorten to be a Short Wheelbase So with those basics I started shopping around and as all of us... I am on a budget. I didn't wanna skimp too terribly because I plan to keep the truck indefinitely, and again, its my daily driver. So parts I went with. *2-1/2" Drop spindles *12.5" drilled and slotted rotors and calipers *bearings, seals, hoses Kit cost- - $500.00 ebay seller: Tomsclassic *Proportioning valve - $40.00 ebay seller: dmcperformance2011 *Upper and lower ball joints - $50.00 ebay seller: logicautoparts *T5 5 speed from an 86 S10 - came with truck *Adapter plate for T5 - $160.00 (I HIGHLY RECOMMEND THIS PRODUCT!) Seller: Hotrod works Link: http://www.hotrodworks.com/catalog/i...1983-cars.html *S10 shift handle and boot - $10.00 (polished cast aluminum rocket shifter from "_craftyb_" on instagram!) Pick N Pull ![]() *Speedometer extension cable - $ 20.00 ebay seller: belair2door *New fuel tank - $170.00 Seller: Summit via Ebay (for free shipping) summitracing_sales *Bad ass finned air cleaner housing - $88.00 Seller: warehouseninteynine *2" drop springs (front) Seller: Brothers *5" drop coils in the rear Seller: Brothers *New drop shocks front and rear - $120.00 Seller: CPP *Late model power brake set up (may not use) *New brake lines - $60.00 Advance Auto supply (Bought the good stuff) *Clutch set from 86 Astro van - $80.00 w/ major discounts Advance Auto parts ONLINE *S10 Short WB drive shaft shortened 1.25" with a conversion u-joint at the rear dif. - $160.00 local shop: Spring Mendors (Norfolk Va.) |
