Old 10-21-2014, 10:09 PM   #1
dremmick
no brake lights
My lights tail lights are acting really weird. I have no running lights and the only way the running lights are on is when I turn the blinker on with the vehicle off. When the vehicle is running I turn the blinkers on and the L and R blinkers flash at the same time. Anyone got any idea what's going on?
dremmick is offline   Reply With Quote
Old 10-21-2014, 10:33 PM   #2
Grumpy old man
Grumpy old man's Avatar
Re: no brake lights
check all your ground wires ,there are numerous threads on problematic lights and your grounds are where you start .
Old 10-21-2014, 10:35 PM   #3
chiefcfd
chiefcfd's Avatar
Re: no brake lights
Unplug the rear harness on the firewall and check each wire with a test lite. Then you know where to start. If everything checks out there look at the rear harness. I had one that got on the exhaust and melted. Caused all kinds of strange lights.
1972 Chevy LWB Roadster
1999 Chevy Silverado 2wd
2015 Chevy High Country 4x4 Crew Cab
chiefcfd is offline   Reply With Quote
Old 10-21-2014, 10:58 PM   #4
dremmick
Re: no brake lights
it looks like there is a brown wire and 3 green ones? I know the Brown is the power supply. What are the others?
Old 10-22-2014, 12:36 AM   #5
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: no brake lights
You should have a brown wire for the tail lights, a dark green wire for the right turn/brake light, a yellow wire for the left turn/brake light, and a light green wire for the back-up lights.
There should be a mid frame connector which has two browns and two light green for the two tail lights and the two back-up lights and the brown wires will also go to the license plate light.
I have a 67 c 10 so I will double check mine and if it is different than that I will post back. VV
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 10-23-2014, 05:45 PM   #6
old Chevy guy
old Chevy guy's Avatar
Re: no brake lights
Sounds like ground issues to me also
old Chevy guy is offline   Reply With Quote
Old 10-28-2014, 07:39 PM   #7
dremmick
Re: no brake lights
I checked voltage at rear connector in frame. The wire coming from the firewall to this connector are working fine. What could be wrong with the wires from this connector to the taillights? We're are the taillights grounded?
