#26 |
house of chevy's
Re: One Piece Windows...install problems...
i think they look bad any way vent windows look alot better
#27 |
yeller
Beauty is in the eye of the beholder.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
#28 |
house of chevy's
i agree
#29 |
El Mero Mero Frijolero!!
I still will. One day.
My Toys: 1993 Ford Mustang LX 5.0 2001 Yamaha V Star 650 1984 Silverado > Build Page < |
#30 |
Chance
![]() Join Date: Sep 2001
I initially ordered the kit from One Piece Products (OPP) for my 1968. I have original doors and the kit did not work out too well. Ben, at OPP, was nice enough to refund my purchase less shipping and the restocking fee of 20%. Since my doors were modified for the OPP kit I decided to go with the Brothers kit. I am hoping to get it by early next week.
1968 Chevrolet Stepside BB 396 w/TH400 1972 Chevrolet 3/4 Ton 4x4 BB 496 w/TH400 |
#31 | |
In the Forgotten far North.
![]() Join Date: Jul 2007
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
#32 |
OPP is the only company making those kits
#33 |
yeller
For 73-87s...cwilke had a 67-72 kit for his truck, a 1968....and there are a couple kits on the market for those trucks.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale Last edited by bigblock73; 06-22-2010 at 11:39 PM. |
#34 |
BAD BOW-Silverado XST
Me neither. I would pay someone else with experience to put them in.
#35 |
hope i can get mine in! worse comes to worse Chris will find a couple huge packages sitting on his porch with a blank check!!
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list ![]() |
#36 |
I have the kit in my truck and it took several hours, lots of profanities and many calls to Ben at OPP but they are in and work good, my only advice is follow the instructions step by step dont jump ahead or you will have to go back and start over, Here is a shot of mine. If I had to do it all over again I would keep my vent windows, that being said if anyone is inetersted I would be willing to trade my stock GM doors with all power options and ventless windows for a set of GM doors with power options that are rust free and dont have speaker holes cutout in the bottom I would also like to get about 400.00 cash. Let me know if anyone is interested. I wont ship so we would have to be able to meet up somewhere for a trade.
"WIDER IS BETTER" (TRUCKS ONLY) |
#37 |
At the body shop.
Anybody else? Im on the fence they look awesome but this thread has me nervous
" That didnt make it any newer " " Dont antique the equipment " |
#38 |
These window kits are stupid expensive I can see 3-400 but a 600 dollar kit is silly IMHO
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
#39 |
At the body shop.
New side glass is 125 a side and 50 for the vents. I dont think its to bad
#40 | |
#41 |
I still don't have windows that go up or seal correctly. They go down fine. I just haven't had time to work on it. I still believe that since I had one of the first kits something was designed wrong with the kit.
1984 Chevy Stepside, 4spd granny, 4 1/2 front/6 inch rear drop. |
#42 | |||
Point number 2, possible customer Quote:
#43 |
My windows are in and go up and down fine. I do not like the outside weatherstrip they give you. I was looking for a universal rubber weatherstrip that was a half inch wider so it seals against the glass when the window is up. It takes a lot of fitting and grinding of the stock hinge bolts. If you take your time you will get it. I would install new power window motors when you are in there.
2010 Tahoe 1984 C10 2005 Harley FLH 1941 Willys Pickup (will never get it done) not for sale |
#44 |
I have same problem on non power windows. I have to apply pressure/direction to window during roll up.
Posted via Mobile Device |
#45 |
Did any of you guys get the windows to work properly? like seal all the way around & go up & down in the proper positions?
#46 |
Nope...but I haven't had the time or money to take it to someone that might be able to get them to actually work as advertised either. Would have rather spent that money on an ls motor or something else. I'll probable scrap them and go back to vent windows. Yes, they don't work that bad! Spend your money on something else! I'm not trying to bash the product too bad but I am! I'll probably end up spending the same amount of money getting them to work that I spent on them and I bet they still won't work! I'm not a betting man either! Either way I'm screwed! Lol...
#47 |
Ok, I have been playing with them for a while & have got them spot on.
You have to take out the door handle & flatten out the top bracket for the rear channel runner so it creates a straight line from top of the door to bottom, then move the whole window winder assy back 1/2 an inch & the same with the front runner, you will need to cut a bit out of the front inside door frame(mine has a support brace that hits the glass & its like a v in two spots) once you have the glass & runners in place & loosely nipped up in the door drill out the three spot welds holding the runner fixed to the door under the inside handle bracket(take the bracket off) make sure the slide is drilled off the door & don't drill thru it. Now move this down maybe 10 - 15 mm & the glass will line up with the back edge of the door in the felt runner. Weld it back on. If you don't move the winder assy back it hits the front bolt that holds the glass to the winder track & jams it up + pushes it forward. When you get everything backwards in the door the glass wont foul on the front of the door it will seal nice & wont wobble like the glass wants to fall out. Remember to put the second slider in the front track & take your time lining up the slides. You will have to trim the side off the door handle to fit behind the rear runner, you can get it to fit & can move the handle back in the door a little as well. If you get really keen there is now room in the front of the door to fit the bottom half of the front runner from the old glass(bottom of the wing glass) flat on the door frame, just cut it up a bit & bend the top side edges out a little to align the glass as it slides down. Find the same rubber seal as what was used from factory for around the the main frame & back edge ( the one in the kit is too big on the sides & pokes out everywhere) & use the thinner one that is still in the new front runner( if you go that far). I have used some spacers to align the front runner (from the kit) between the door body & runner to sit the glass in the middle of the door opening, this helps as well. if you decide to go ahead & make them fit & get stuck I will give you some more advice ... Put on some good music & stay calm, it was frustrating for me but if you can do it like this it wont be for you. I would come & do it for you but I live in Australia & have one of two sets here now I know why the bloke sold them to me! Great concept & awesome look just poor planning. Last edited by ty598; 10-21-2014 at 09:42 PM. |
#48 |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
ty598, I don't quite get what you are doing. Of the last 10 kits I have sold, one had issues, the others have not. One of the 10 was a personal friend of mine and he never called me and got them in with no issues.
In this post is the one that had problems, prior to that, this is the only other issue I have heard of http://forum.73-87chevytrucks.com/sm...?topic=28902.0 2 others posted above you that they got them in and rolling up/down. I also have a set that is working fined and will have another set going in my pickup soon.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
#49 |
My windows fit like factory & wind up and down perfectly now ......Before they sat nose down with a gap at the back top corner & flopped around a bit when they were half up & down. With what I have done they run in the back channel all the way up & down, foul on nothing & have room for the front slide I made stopping the front of the glass from touching anything in the way of long bolts or the spotted in nuts for the hinge, they run inside of them in I also changed the felt window surround to the same size as the factory fitted one & it sits smooth all the way around the window frame. For me near enough is not good enough. I have owned my body shop for 25 years so I have the ability to understand the issues & fix them. All said I still really like the kit & would do it again .....This way.
