Old 10-21-2014, 05:33 PM   #1
gmebey
Sway bar bushing
I'm rebuilding the front of my truck and I think at some point in the past 45 years someone may have switched out the original sway bar for a thicker one.
Mine measures 1-1/16", but the bushing I got in my kit measure ~7/8".
Is this correct?
gmebey is offline   Reply With Quote
Old 10-21-2014, 06:06 PM   #2
Sammy
Re: Sway bar bushing
Yes, 7/8" is the standard for a C-10...But in the past few years folks have been adding the heavier sway bars. Pretty common to add a sway bar to a truck without one and if readily available using the larger bar.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 10-21-2014, 06:41 PM   #3
cdowns
cdowns's Avatar
go to autoparts store and get the right size
Old 10-22-2014, 11:24 AM   #4
stomper
Junior Member
stomper's Avatar
The Moog part numbers are on here somewhere for the 1-1/16 and 1-1/8 bars. Be aware there are earlier (bigger) and later (smaller) style brackets for the sway bar bushings. You will need the number when you go to autoparts store.
"I was patina when patina wasn't cool."
1973 Cheyenne SWB Sunset Gold / Frost White / Saddle
stomper is offline   Reply With Quote
Old 10-23-2014, 12:25 AM   #5
gmebey
Sorry but I have another question.
Is the greaseable bushing a worth while upgrade?
Old 10-23-2014, 12:32 AM   #6
leddzepp
Moderator
leddzepp's Avatar
The bushings for a sway bar are either rubber (OEM) or polyurethane. I am not aware of any that are greaseable
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 10-23-2014, 07:15 AM   #7
67c10rustbuket
67c10rustbuket's Avatar
The poly bushings from Energy Suspension are greaseable. you grease the clamps on the frame where the bar pivots so they don't squeak at you. Mine are 1 1/16" and I always heard that was the OE small bar. I have never heard of a 7/8" bar but I'm wrong quite frequently.
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 11-14-2014, 11:55 AM   #8
gmebey
I went with the Energy Suspension kit with the brackets
Old 11-14-2014, 01:13 PM   #9
bs46488
I just bought a set of those same bushings.
Since only 2 of them are greaseable, do the grease fittings go on the frame mounts or the a-arm mounts?
bs46488 is offline   Reply With Quote
Old 11-14-2014, 05:28 PM   #10
gmebey
Frame. Mine came with instructions.
Old 11-14-2014, 07:07 PM   #11
mechanicalman
Hrrrummmph! What kind of grease are you supposed to use, silicone?
mechanicalman is offline   Reply With Quote
Old 11-14-2014, 09:57 PM   #12
gmebey
I used the silicone grease that came with kit for the control arm bushings, and regular grease that I use for the rest of the chassis. The instructions said to use three pumps at the regular maintenance intervals.
Old 07-19-2017, 12:39 AM   #13
ryanv70c10
So are the frame bushings and control arm bushings identical? Thanks!
ryanv70c10 is offline   Reply With Quote
Old 07-19-2017, 04:23 PM   #14
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Yup.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
