Old 10-22-2014, 09:35 PM   #1
dcmalone
dcmalone's Avatar
Spindle Interchange?
Does anyone know if front spindles off a 50 will interchange with a 55.2? I have one that has a little wear on my 2nd series and have a source for a pair off a 1950. Any help would be appreciated.
dcmalone is offline   Reply With Quote
Old 10-22-2014, 10:34 PM   #2
whitedog76
Re: Spindle Interchange?
Hopefully this helps.
http://chevy.oldcarmanualproject.com...resto/5071.htm
http://chevy.oldcarmanualproject.com...55ctsm0314.htm
I'm not familiar with the 1/2 tons, but the 3/4 tons were interchangable to 59.
Bearings changed in 52 when they switched from huck to bendix style. Also the kingpin length was slightly different. The later ones were longer, so you would need kingpins from whatever year you will be using.
whitedog76 is offline   Reply With Quote
Old 10-23-2014, 05:51 PM   #3
dcmalone
dcmalone's Avatar
It does indeed help. It should work if I use the 1950 kingpins. Thanks for the help.
