#24 | |
Re: 54 GMC, S10 swap, OM617 diesel
I did use an AX-15 from a 2wd jeep, I have lots of friends into jeeps (thats sort of what spawned the idea for the OM617 in the first place) and after many 2wd to 4wd trans swaps, 2wd trans are a junkyard item in the 4x4 world of jeeps so that was a no brainer! I did get the koch enterprises adapter, which was inexpensive and spot on as far as hooking it all up. As far as changing the steering setup, I didnt even try. The way the steering is in the first place is goofy IMO, I didnt want to mess with any of it and try to change angles and pieces. It was easy enough to notch the pan that the headache of changing steering arms etc just wasnt something I wanted to get into. Besides all that, pelican parts has lower oil pans for around $20 if I failed and needed to buy a replacement pan. I really enjoy welding, and it was just fun to notch it and make it work that way. Also as far as it being set up so high, I actually like it and it really worked out well. It looks like it belongs there, not all sunken in like a 350 looks. My driveline is still low to the ground, but I did do a trans tunnel inside (again I like welding so it was fun to construct) Other than the clanking and rattling of old tin, it drives amazing. It steers easy, even with a manual steering box, and has no body roll or feeling of unbalance. For being my first 'complete build' it all fell into place nicely, shifter position, pedals, etc. Feel free to ask any other questions or I would be glad to show pics. I had to sort of figure all this out on my own without much to look at since I still haven't seen any others done in an AD truck! ![]()
54 GMC OM617 diesel swap http://67-72chevytrucks.com/vboard/s...d.php?t=588827 87 Chevy Crew Cab Cummins http://67-72chevytrucks.com/vboard/s...d.php?t=711157 |
