Old 10-23-2014, 08:19 PM   #1
zipper
Disc Brakes
I'm looking to upgrade my drum brakes to disc brakes and looking at purchasing a conversion kit. The kits I have stumbled upon are the brothers, ece, and cpp. Since brothers is having a sale, the kit is alot cheaper than the others. I remember reading the kit does not include the master cylinder and another part needed. So what I'm asking what is this kit missing and is it a quality kit? Anybody have experience with the kit?
http://www.brotherstrucks.com/prodin...number=DBC6L20
zipper is offline   Reply With Quote
Old 10-24-2014, 06:45 AM   #2
PGSigns
PGSigns's Avatar
Re: Disc Brakes
Have you been through the disc brake conversion thread? It has all the info on doing the conversion for a lot less money. What other plans or upgrades do you want or plan like power brakes and power steering? Knowing that will help get you a complete list.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 10-24-2014, 07:13 PM   #3
zipper
Re: Disc Brakes
I plan to have no power steering or braking. I would like to keep my 6-lug to and I have a 68 crossmember installed on my truck. The reason I'm looking at getting disc brakes is so I can use drop spindles.
Old 04-24-2015, 10:29 PM   #4
zipper
Re: Disc Brakes
Bumping this old thread. Will this kit come with everything I need to upgrade to disc brakes? It doesn't mention anything about a proportioning valve, so would I also have to order that to have power disc brakes? Also will I be able to clear 15's with this kit? I know most people will say order from ECE but living in Alaska makes that kit cost $480 to ship.
http://www.ebay.com/itm/mcgaughys-19...item43ad9a815f
Old 04-25-2015, 12:00 AM   #5
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Disc Brakes
You need a dis/drum prop valve or an aftermarket adjustable prop valve with disc brakes.
Does matter if they are power brakes or manual.
Keith
Convert to disc brakes.
Old 04-25-2015, 12:01 AM   #6
lolife99
lolife99's Avatar
Re: Disc Brakes
That kit is a 6-lug kit.
It will clear oem 71-87 15" steel wheels made for disc brakes.
It will not clear pre-1971 6-lug 15" steel wheels.
Keith
Old 04-25-2015, 12:02 AM   #7
lolife99
lolife99's Avatar
Re: Disc Brakes
Have you contacted any of the board Vendors?
Keith
Old 04-25-2015, 03:21 AM   #8
zipper
Re: Disc Brakes
I've contacted a few and shipping is always over $300 atleast to alaska. If I also added this to the kit would that be all I need?
http://www.mcgaughys-suspension.com/...le-part-63163/
Old 04-25-2015, 03:52 AM   #9
zipper
Re: Disc Brakes
Which of these would be best? The non adjustable says it comes with the brake lines and the hardware, the adjustable one doesn't say if it does.
or
http://www.mcgaughys-suspension.com/...ve-part-64090/
