Old 10-22-2014, 11:31 AM   #1
Nitis
Nitis's Avatar
Tunes for an LS
So I see lots of chatter about tuning these engines in swaps. But what about ones in their factory state?
My wife drives a 2003 yukon. Only 83k miles. But it just feels a little sluggish and gets not very good mileage
Yes unknown typical tune up is probably due but what about a "tune"?
Nitis is offline   Reply With Quote
Old 10-23-2014, 03:43 PM   #2
Billett
Billett's Avatar
Re: Tunes for an LS
There's plenty of untapped power in these from stock form. Mine is a 100k mile+ bone stock engine save for DT headers. Got it tuned on a dyno by a local shop (that I'm not too fond of anymore) and it is making around 300whp/320ft-lbs. Stock is supposed to be 300-325hp and 360-370 ft-lbs at the crank. Considering this is going through a 2 piece drive shaft and very heavy 4l80 I'd say either those headers are miracle workers or the stock tune is just a little on the safe side!
I would get it done at a local tuner in person, not an online tune. Regardless of power, changing the shift points can make a big difference. Can't say you're going to pick up any mpg's though...
Will
1968 C10 - Project Texa Go 6.0/4L80e
2003 Mitsubishi Lancer Evolution
2002 Ford Excursion 7.3L
2024 Toyota Sienna
Billett is offline   Reply With Quote
Old 10-23-2014, 03:48 PM   #3
Wasted Income
Boosted Member
Wasted Income's Avatar
Re: Tunes for an LS
You can get more aggressive with the timing, and DFCO to increase the fuel economy a bit. More power can also be had from timing and some power enrichment tweaks.
It will "feel" more fun to drive with some changes to the throttle body vs pedal position table, shift time and pressure, torque management, abuse management. GM leaves plenty on the table with a stock tune.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 10-23-2014, 05:09 PM   #4
e015475
e015475's Avatar
Re: Tunes for an LS
You might try this guy-
www.nelsonperformance.com/
or
www.wait4meperformance.com
Both have mail order tuning services. I've used both with good results
e015475 is offline   Reply With Quote
Old 10-23-2014, 07:46 PM   #5
Daaaanz67
Re: Tunes for an LS
Put it on rollers and have a live tune.
Daaaanz67 is offline   Reply With Quote
Old 10-26-2014, 02:06 AM   #6
Angryman117
Re: Tunes for an LS
Always go with a local shop if you can, they can dial it in better than an online tune.
Angryman117's
47 Chevy Build
89 Silverado Z71 LS Swap (sold)
Angryman117 is offline   Reply With Quote
