Old 10-26-2014, 12:29 AM   #1
IdahoMan
What's behind your seat..?
Hi all!
The following is a thread that I made on another 73-87 truck forum here: http://forum.73-87chevytrucks.com/sm...6515#msg246515
(Check out the CUCV M1028)
I'm still looking for some inspiration. Saw a nice custom wood shelving mod by poster "tucsonjwt" here: http://67-72chevytrucks.com/vboard/s...4&postcount=30
tucsonjwt, did you follow a template for that?
Looking for ideas for organizing the area of the cab behind the seat. Looking for your input on what to have, how to store/install it. Anyone seen a truck of our kind that has been used in a military/police/security/fire capacity? I'd imagine they'd have a sturdy setup for equipment.
Rough Ideas:
Items:
Flash Light
Fire Extinguisher
Firearm
Med Kit
Trash Container
Tools
Ice-Scraper/Squeegee
Oil/Trans Fluid
Interior Body:
OEM Panelboard (what I have now)
Caged/Custom
Mods:
12V Cig Socket
USB Power Socket
Custom wired holster for LED FL charging
Rifle Rack
FE bracket
Small Safe
So, what's behind your seat? What's your setup? Any pics?
Where do things attach, weld, wire or screw into, and what's the proper way of going about it?
Mine (Panelboard not in at the moment):
Sincerely,
IdahoMan
IdahoMan is offline   Reply With Quote
Old 10-26-2014, 08:18 AM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: What's behind your seat..?
One big box with two 12" competiton woofers. Both powered by a nice stainless steel amp. Eardrum busters even with the windows rolled down!
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 10-26-2014, 10:28 AM   #3
Tucson38
HiLift Jack, heavy down jacket, 4-way lug wrench.
Tucson38 is offline   Reply With Quote
Old 10-26-2014, 11:46 AM   #4
meatwagon83
meatwagon83's Avatar
this, 2 6x9s and a 10 inch sub
"DON'T TOUCH THE TRIM!!"-Early Kyler
meatwagon83 is offline   Reply With Quote
Old 10-26-2014, 01:37 PM   #5
xole
xole's Avatar
2 6x9's, power slider motor, rifle rack.
'86 Chevy K10 SWB Custom Deluxe 4x4
'94 Chevy Corvette
'07 Ford Mustang
'08 Lexus LS 460
xole is offline   Reply With Quote
Old 10-26-2014, 10:25 PM   #6
epon
epon's Avatar
'82 C-10 SWB / C'd, Z'd, Body'd and Bagged / Shaved firewall, wiper cowl, drip rails, stake holes and tailgate/ 20" & 22" Milanni Voodoo
'81 C-10 SWB Parts Truck
IRC - http://webchat.snoonet.org/#baggedtrucks
epon is offline   Reply With Quote
Old 10-26-2014, 10:31 PM   #7
Bears63
...just another truck junkie..
Bears63's Avatar
The way my adventure has been going probably another huge mouse nest and more poop and urine! I'll find out for certain tomorrow night.
Mike "Bear" Shea
Bears63 is offline   Reply With Quote
Old 10-27-2014, 01:00 AM   #8
tucsonjwt
No template - just measured with the seat all the way back - so no rubbing anywhere. I used 3 self tapping sheet metal screws in the lip under the window in the vertical recess spaces so the short screws would not penetrate the back wall of the cap - plenty secure. The custom cab corner speaker boxes were also very handy and no cost to build using scraps I had available.
My best advice - lay out everything you want to store and then design a storage bin to accommodate each item. Store most frequently used items on top and outer cubbies.
This is basically just a big open front triangle with a 1/4" plywood back and 1Xs and other plywood pieces for the shelves and dividers. If might be a good idea to just use cheap plywood or MDF or even OSB if you are undecided on what you want so you don't waste expensive stock. Actually, nobody will see it back there so cheap stock is probably the most practical option.
tucsonjwt is offline   Reply With Quote
Old 10-27-2014, 11:07 AM   #9
tucsonjwt
Some recent pics with storage utilization.
Old 10-27-2014, 12:05 PM   #10
Dead Parrot
Bought this behind the seat shelf setup many years ago. I think it is a Rubbermaid product. Found it at Pepboys. Cut some carpet pieces to line the bottoms of the shelf areas to cut down on rattles.
Dead Parrot is offline   Reply With Quote
Old 10-27-2014, 02:42 PM   #11
riz
Dee Zee Inc. #CO75 around $90.
RIZ
riz is offline   Reply With Quote
Old 10-27-2014, 03:15 PM   #12
Sodak
Active Member
thanks just ordered that.
Sodak is offline   Reply With Quote
Old 10-27-2014, 03:46 PM   #13
IdahoMan
DP,
Is that a Halon 1211 Extinguisher you have there? I'm thinking of getting one fo those.
IM
Old 10-27-2014, 04:36 PM   #14
Dead Parrot
DP,
IM
Nope. Just a 5 BC dry chem. I do have a small Halon 1211 I got years ago on closeout. Keep it near my computers and home entertainment stuff. Halon is a use and run product. Any of the Halon that gets transformed by the fire tends to mutate into deadly stuff.
Also have a 5lb CO2 that someone was tossing. IIRC, it was about $45 to get it re-certified and refilled.
Old 10-27-2014, 09:02 PM   #15
tucsonjwt
My reason for not going with the plastic store bought box again is that I wanted long bins for items, like the jack and handle and rolled up jumper cables, etc., and the purchased box had relatively small fixed shelves.
Also, if a long gun were stored I would want to put it in a custom sized cubby with a locking front panel hinged on the bottom side. I have known guys who had their rifle stolen from their truck and it was an easy grab and go for the thief. I think if a thief has to do some extra looking and fiddling to break another lock or two it might slow him down enough to think twice about dawdling around.
Old 10-28-2014, 12:33 AM   #16
y5mgisi
Second Chance Program
y5mgisi's Avatar
I gotta do this too.
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 11-10-2014, 01:45 AM   #17
TKCR
TKCR's Avatar
My 86 C10 Silverado
Old 11-11-2014, 06:13 PM   #18
wilkin250r
wilkin250r's Avatar
This is the best one I've seen. It's more speaker-oriented, but the concept can be adapted to anything. If this was his first attempt at fiberglass, maybe results like this really are attainable by the average Joe.
http://67-72chevytrucks.com/vboard/s...ght=fiberglass
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!!
wilkin250r is offline   Reply With Quote
Old 11-12-2014, 08:59 AM   #19
TexasJeff
Don't Crush em Restore em
TexasJeff's Avatar
Here is another thread of the same subject.
http://67-72chevytrucks.com/vboard/s...d.php?t=518611
TexasJeff
2009 Silver with Linen Interior Cadillac DTS
1990 Red with White Top and Interior Ford Mustang GT convertible
1998 Red with Gray Interior, C3500 Chevy Crew Cab Dually
TexasJeff is offline   Reply With Quote
seat, storage
