01-21-2004, 10:09 AM | #1 |
This, is my BOOMSTICK!
Power booster conversion?
I just pulled a power brake booster from my brother in laws old blazer, I believe it's a 77. Of course my 67 has manual brakes and does not have the same bolt up pattern. What do you guys do to mount the booster.
I was thinking of spot welding it to the firewall, but if it goes getting it off won't be fun to remove. I was also thinking of cutting the mounting plate off of the blazer and welding that into my truck. I don't know. What is the easiest way to go about this and what else am I going to have to convert to make this work. Thanks guys (and girls)
Larry Got rid of my projects for now. 1980 Jeep CJ7 1998 Nissan Sentra (my car) 2001 Toyota Sienna (wife's, of course) |
01-21-2004, 11:00 AM | #2 |
ttt
01-21-2004, 01:08 PM | #3 |
ttt
anybody?
01-21-2004, 01:22 PM | #4 |
On my 67 I bought a power booster that fit and it bolted right up.Still have the 4 drum brakes but I don,t have to push the pedal right to the floor to get it to stop.
01-21-2004, 01:22 PM | #5 |
Resident Curmudgeon
Okay, I understand the cost factor, but it would be much easier (time=$) to purchase the correct booster firewall bracket and pedal rod. A drum brake setup for 1/2 ton or 3/4 ton will work and should be readilly available. You also get the added benefit of not having to remeber what year the part is when replacing or mixing/matching parts. This of course assumes that your goal is to have power brakes and you are NOT trying to fabricate a flush mount booster to clean up your firewall.
This does not address your question but is simply advice from someone whos been there and done that.
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
01-21-2004, 01:52 PM | #6 |
Thanks alot CPNE. I didn't realize that they even sold the power booster firewall bracket. Very helpful, Thanks again.
01-21-2004, 02:05 PM | #7 |
Resident Curmudgeon
I think I've seen it repo'd but used will do. Just make sure you get the complete setup including rod to pedal. Your manual brake rod won't work. Post a WTB on the parts board.
01-21-2004, 03:58 PM | #8 |
I took the brake rod and everything exept for the brake pedal and arm itself. I hope the brake rod matches up with my stock brake assembly.
