Old 10-24-2014, 07:08 PM   #1
Mv7fd
Initial start
I want to make sure oil comes up through my pushrods before I button everything back up what are the best ways to do this
Mv7fd is offline   Reply With Quote
Old 10-24-2014, 07:56 PM   #2
geezer#99
geezer#99's Avatar
Re: Initial start
Prime it with a drill. Cut down an old dizzy or buy a priming tool.
http://www.autozone.com/loan-a-tools/oil-pump-primer
Old 10-24-2014, 08:12 PM   #3
Just call me Sean
Just call me Sean's Avatar
Re: Initial start
I usually disconnect the coil and crank the engine for a while.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 10-24-2014, 08:35 PM   #4
Mv7fd
Re: Initial start
I bought the tool. 30 bucks
Old 10-24-2014, 09:45 PM   #5
Corts60
Just here to tinker
Corts60's Avatar
Re: Initial start
Do not do this.
Buy a priming tool as stated above or remove the gear from an old distributor and use that as your tool. The most important part of the store bought priming tool is that it has the middle bushing to complete the oil galley to the top end. Some cheap ones only have the top bushing and rod. You can only prime the bottom end without the middle bushing.
Use a 1/2" corded drill to run the tool. Battery power will not do it. And install a mechanical oil pressure gauge to check that your bearing clearances are as should be. Correct clearances should yield you well over 50 psi on a new build.
Remember the camshaft lobes have no direct oil feed. The get oiled by splash only so it is important to get those RPM's up right when you fire it. Those first 10 seconds are critical, unless you have a roller cam.
Old 10-24-2014, 09:56 PM   #6
Mv7fd
Re: Initial start
Bought the tool ran it with a cordless drill saw oil on the driver side didn't see it much on the passenger side I assume that is ok
Old 10-24-2014, 10:10 PM   #7
Just call me Sean
Re: Initial start
Originally Posted by Corts60 View Post
Do not do this.
No explanation, just don't do this? If assembled properly with lube and oil in the right places and the coil not firing so there aren't any loads placed on the bearings I don't see a problem.
Old 10-24-2014, 10:12 PM   #8
Mv7fd
Re: Initial start
This isn't a complete rebuild either just new cam lifters push rods and rockers so is it as big of that oil isn't coming out of each push rod
Old 10-25-2014, 08:30 AM   #9
Jake Wade
Jake Wade's Avatar
Re: Initial start
You need to turn engine stopping every 90º until you make a couple revolutions. It takes a little while for oil to come up through all the pushrods.
Jake Wade is offline   Reply With Quote
Old 10-26-2014, 06:54 PM   #10
Mv7fd
Re: Initial start
started the truck last night. that was a little bit of a pain i had the rockers to tight so it didn't start at first and i had plug wires wrong on the distributor. after getting that all straighten out she fired off had to adjust the timing some wasn't bad i've had it out running around town today runs awesome i don't think i did to bad for my first time ever digging this far into a motor
Old 10-26-2014, 07:40 PM   #11
geezer#99
geezer#99's Avatar
Re: Initial start
Did you run it for 20 minutes to break in the cam/lifters?
Old 10-26-2014, 07:44 PM   #12
Mv7fd
Re: Initial start
Yes I ran it for about an hour last night 30 mins a piece varying RPMS then did it again today 2 times for 10 minutes
Old 10-26-2014, 08:31 PM   #13
chengny
chengny's Avatar
Re: Initial start
Put heat lamps on the oil pan for a few hours prior to a pre-prime. This will lower the viscosity of the oil.
Pumping that thin oil will be way easier and will also aid immensely in getting flow throughout the entire lube oil system.
For basically the same reasons, heat lamps should also be used if a cam break-in has to be conducted in an unheated garage - during periods of cold weather.
chengny is offline   Reply With Quote
Old 10-26-2014, 10:07 PM   #14
enaberif
Re: Initial start
I'm going to be using one of these to do as you say and far more efficient than a heat lamp.
enaberif is offline   Reply With Quote
