10-27-2014, 04:44 PM | #1 |
01 Tahoe tune up?'s
I am getting ready to do a tune up on my 01 Tahoe with a 5.3ls. It has 114,000 miles and was going to do plugs and wires. How often are you supposed to change out the coil packs? Is there anything else that can be done? I am used to the gen 1 sbc's.
Thanks! |
10-27-2014, 05:08 PM | #2 |
Re: 01 Tahoe tune up?'s
I personally wouldn't worry about the coil packs unless you have an issue with them. I would say plugs, wires, serp belt, and a/c belt. That's what I did on mine when I first bought it. I've got 250k on mine and replace things as soon as they start to show issues. Pretty sure I'm on the original ones.
I'd say you've got some time, but would plan to do the fuel pump/filter at some point. They like to go out at the most inopportune time. I got fortunate on mine in the fact I was able to get it home. Most I know goes out to their truck in a parking lot and it won't fire up.
Ryan 1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840 1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628 1967/71 Blue SWB C10..SOLD 1977 SWB K10..my grandpa's.....never should have sold |
10-27-2014, 05:26 PM | #3 |
Never. You only replace one when it dies. It either works or it doesn't (well, it can have intermittent spark, but it will still throw a code). You'll know when one dies because it throws a code and it will run funny. My 00 has all the original coil packs with 160K on it. I've never heard of anyone have more than one die at once. And if one does die, you only need to replace that individual pack.
Agree with the above... the "average" fuel pump seems to last between 120-140K. Mine lasted until 126K. I got lucky, mine gave me a warning, the check ball started going so the truck was "starting hard." Fuel pressure test showed the pressure was dropping to zero when it was shut off (check ball supposed to hold pressure so truck starts as soon as you turn key.) In addition to the belt I'll throw in change the tensioners and idler pulley as well. OEM ones aren't expensive (made in Canada). Mine started squealing around 100K.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
10-27-2014, 08:27 PM | #4 |
I already did the fuel pump, filter and i put on new stainless brake lines, stainless fuel lines, and new tranny lines. It was a pain as to do all the lines you basically have to remove everything from underneath the truck.
