Old 10-26-2014, 10:58 PM   #1
AirSpeed
AirSpeed's Avatar
Any way to brighten up a quadrajet?
I just cleaned my quadrajet, got all the crap off it but is an ugly color. Is there anything I can spray on it to brighten it up? I was thinking acid but I've seen acid eat die cast parts. Any suggestions?
AirSpeed is offline   Reply With Quote
Old 10-27-2014, 01:33 AM   #2
PDXk5
PDXk5's Avatar
Re: Any way to brighten up a quadrajet?
I have used Simple Green to soak things in over night and they have come out sparkling clean. Here is the original carb riser, hose clamps and spark plug heat shields from my rig after soaking in simple green over night. No scrubbing or polishing just soaking.
I have heard that one could do an entire carb and get the same results but I have not tried it.
PDXk5 is offline   Reply With Quote
Old 10-27-2014, 04:57 AM   #3
Sklptrljay
Sklptrljay's Avatar
http://www.how-to-build-hotrods.com/soda-blaster.html
This looks pretty cool.
1971 C/10 SWB, 15x8 Rallys, 4.5" X 7" static drop, C-notched, 350/350, 3.73 Posi. .........A 383 and Gear Vendors are on my bucket list.
1972 GMC 4X4 K1500 Survivor - Sold
No matter what problems life throws at you, your time on Earth can be incredibly fulfilling and rewarding.....if you just lower your expectations. -Phil Dunphy
Sklptrljay is offline   Reply With Quote
Old 10-27-2014, 09:26 AM   #4
no1udknow
no1udknow's Avatar
Theres some stuff that jimbosprint used on his exaust headers, I think it may only be for cast iron, but it might be worth a try, its called, Calyx.
Built not bought!
My dad always tried to convince me HEI was pointless!
Welding is a lot like sex, you don't have to be great with the rod as long as you thoroughly prep the surface and your good at grinding
My build : 68 C10 Short Bed Conversion
no1udknow is offline   Reply With Quote
Old 10-27-2014, 09:50 PM   #5
PDXk5
PDXk5's Avatar
Originally Posted by Sklptrljay View Post
That does look pretty cool and easy to do. I will have to try this out!
Old 10-27-2014, 09:53 PM   #6
AirSpeed
AirSpeed's Avatar
I have the tube and a air nozle with a long tube that will work perf! Gonna try it tomorrow.
Old 10-27-2014, 10:28 PM   #7
Steeveedee
Who Changed This?
Steeveedee's Avatar
Try this guy-
https://www.facebook.com/pages/Every...91958290844413
~Steven
Simi Valley, CA
Old 10-27-2014, 11:03 PM   #8
AirSpeed
AirSpeed's Avatar
Post Re: Any way to brighten up a quadrajet?
Originally Posted by Steeveedee View Post
Can't get the link to work.
Old 10-28-2014, 09:34 AM   #9
brown7373
brown7373's Avatar
Eastwood sells a "Carb Renew" that approximates the original goldish color. I wouldn't use Calyx on a carb. There are too many linkages that need to move smoothly and that could really gum them up.
brown7373 is offline   Reply With Quote
Old 10-30-2014, 07:47 AM   #10
Freddy67
Pull it off and put a Holley on it? Thatd brighten it up in imo! ;-)
Freddy67 is offline   Reply With Quote
Old 11-01-2014, 12:08 AM   #11
profe56
I want to know where can can I buy the air gun atachment.
profe56 is offline   Reply With Quote
Old 11-01-2014, 12:17 AM   #12
litew8
litew8's Avatar
I don't get it. Why not use carb cleaner? Soak overnight.
project: "my happy mess"
litew8 is offline   Reply With Quote
