Old 03-07-2014, 04:53 PM   #1
peelintire
positive camber disc brake?
Hi all;
I need a little help. I had my truck 64 c10 converted to disc brakes using -
1998 spindles and 81 lower control arms. Recommended on this site. the problem is my camber is out 2.2 degrees, any one no the problem, and how I can fix it?-
I know I can use 73-87 spindles, but I have to get lots of other part to change over. will 71- 72 spindles be easier and less work/$ only need upper ball joint, but newer calipers will not fit. want to stay 6 lug. I am pretty sure the spindle is the problem!
peelintire is offline   Reply With Quote
Old 03-07-2014, 05:03 PM   #2
1963c-10
1963c-10's Avatar
Re: positive camber disc brake?
Welcome to the forum.. Check through the FAQ's section. You'll find about every answer you can think of brake related (and most other projects).
Link: http://67-72chevytrucks.com/vboard/s...d.php?t=559678 Look under section 2B
1964 Short bed trailer
Old 03-07-2014, 05:33 PM   #3
BMERDOC
BMERDOC's Avatar
Did you have it aligned or do you have your own camber gauge? How thick are the shim stacks? Are both sides equally 2.2? Do you know what it was before the swap?
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 03-08-2014, 12:53 AM   #4
Captainfab
60-66 Nut
Welcome to the forum Mark
Glad to see you were able to get registered.
As for changing to the '71-'72 spindles or the '73-'87, the only difference in cost that I can think of is the extra cost for the '71-'72 uper balljoint. You will have to change the lower control arm back to a C10 arm and then change the balljoints to the correct ones for the spindles used. Then there will be the tierods to deal with.
Since it sounds like you have everything together right now, it may be easier and cheaper to figure out how to fix the camber issue. Would it be possible for you to post a pic of the upper control arm bolted up, so we can have a visual of what you have?
Do you have any idea on what that 2.2 degrees would amount to in a measurement at the upper control arm shaft?
Old 03-08-2014, 12:57 AM   #5
Captainfab
60-66 Nut
To my knowledge, no one has an answer to this issue yet. I have seen 2 other members with this same issue, but no response as to a fix. I just do not have the time to make this conversion on my Suburban, so I do not have an answer for the OP.
The OP told me that all the shims are removed. I assume that he had an alignment done, but I did not ask that specifically.
Old 04-23-2014, 12:42 AM   #6
peelintire
I have switched to 79 hd 1/2 ton of a van, seams to work just need to be aligned ! - and get after market 6 lug rotors.;- This project has been a nightmare.--- If you put info on here ,make sure it is correct!!!
I also see the bad info is still on here. cost me $$$$$$
Some one should take it down!.:
Have 89-98 3/4 ton 6 lug rotors and spindles, with backing plates, new bearings and seals for sale. Also so have lower control arms off 81 3/4 ton, all have been blasted and powder coated.Have new brake pads too, no calipers. $ 225 for all. this does not include what it cost me for powder coating.
Thanks!!!...
Old 04-23-2014, 06:37 AM   #7
PGSigns
PGSigns's Avatar
I don't think the 88 and up swap has ever gotten worked out. Using the 73 to 87 C10 parts is well documented and well sorted. Hope the van stuff works out.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 04-23-2014, 10:16 AM   #8
peelintire
Thanks Jimmy,
Old 10-28-2014, 04:20 PM   #9
peelintire
79 van front disc spindles work!
Old 10-29-2014, 12:25 AM   #10
Captainfab
60-66 Nut
The full size vans use the same spindle as the '73-'87 C10 pickups, Suburbans and 2wd K5 Blazers.
Old 10-29-2014, 06:22 AM   #11
lolife99
67-72 parts collector,…
lolife99's Avatar
Glad to see the 88-98 spindle issue come to the forefront.
Just because the parts bolt together doesn't mean it's correct.
Use conversion 60-62, or 63-70 spindles and drop spindles,... Or use 71-72 and 73-87 spindles or drop spindles on these trucks.
If you want 6-lug rotors, buy aftermarket rotors.
It's easy now.
30-40 years ago it wasn't.
Keith
Convert to disc brakes.
