Old 05-18-2014, 12:31 PM   #1
JulioK
JulioK's Avatar
Sources for 3 speed saginaw OD
Like so many folks I'm hunting for a saginaw 3 speed with BW OD. What other vehicles used that setup? Were there cars that used them and if so would they easily adapt to my truck? (I mostly just drive it and am not hauling stuff much) What years were they produced? I have the 7 bolt non OD with my 72 lwb but run up and down the interstate several days a week. I believe the units below are what I'm looking for.
"The GM designation for the Saginaw is SM326. The tail housing on a Saginaw OD will have "R10Q-1" cast into it."
Needle in a haystack?
1972 c10 Stepside lwb 307 2bbl
JulioK is offline   Reply With Quote
Old 05-18-2014, 07:22 PM   #2
SS Tim
SS Tim's Avatar
Re: Sources for 3 speed saginaw OD
Might want to read through this thread to catch up on where I stand on these.
http://67-72chevytrucks.com/vboard/s....php?p=6625706
You would, I feel, be much better off with a later 5-speed trans swap like a T-5. http://67-72chevytrucks.com/vboard/s...d.php?t=482069
Or even a NV3500.
If you wanted to keep a column shift look into an Advance Adapters Ranger O/D that fits between the bell housing and the trans.
SS Tim is offline   Reply With Quote
Old 05-18-2014, 10:14 PM   #3
JulioK
JulioK's Avatar
Thx for your reply. I had read thru your previous post already and many others on the internet. I really like the 3OTT and don't intend to drive any long distances in it. The ranger has promise but I don't want to spend a lot of $$. Still trying to research the history and use of that saginaw with BW OD.
Old 05-18-2014, 11:51 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
I think the '55-'57 Chevy cars used them but I don't know if they were exactly the same or not....
I'll look at the one I have and see what it says on the tail housing....
LockDoc
Leon
Old 05-19-2014, 01:23 AM   #5
frank69
They used them in cars from 55 to early 60's but they were the old thans with no synchro in 1st gear. I bought 1 at Pomona about 15 yrs ago, sold it a couple years later and that's the last one I've seen in captivity.
frank69 is offline   Reply With Quote
Old 05-19-2014, 01:35 AM   #6
faribran
Do you really want non synchro?
faribran is offline   Reply With Quote
Old 06-03-2014, 12:53 AM   #7
faribran
Mine came from the factory in a 67 Malibu station wagon. Behind a 283. Mine is fully synchro
Old 06-03-2014, 01:09 AM   #8
In The Ten Ring
I really like 3ott also: an overdrive would be helpful.
In The Ten Ring is offline   Reply With Quote
Old 10-29-2014, 11:54 AM   #9
sc_frontier
sc_frontier's Avatar
I've heard the non-syncro is not an issue since the overdrive can free wheel. This also allows clutchless shifting.
SC
sc_frontier is offline   Reply With Quote
