Old 10-29-2014, 12:25 PM   #11
99 to Life
99 to Life's Avatar
Re: 51' 3100 build in PA New to Site
steve, sorry for the belated reply. typical cab mount measurements are taken from top of bushing that goes on your fabbed up mounts down to the top of frame. Up front on the cab the mounting point is different because they used shackles in the back. But the s10 frame actually dips down where the front mounts would be, so it kinda offsets itself a little bit. If anything the back mounts can be adjusted by maybe half and inch, but its really not going to be noticeable.
I'd get the mounts clamped onto frame, put your bushing on there and get cab on, see if you like the height, which is hard to tell without the clip and running boards on. as long as you don't go over 4" off frame height you'll have a good stance with the 2/3 static drop you have (which is what my 51' is)
Just note the way you mount your bed, if its too high, your running boards are gonna too much rake and be higher in the back. you could mount bed a little lower and give it a slight taildragger look, keeping boards even closer to ground.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
1951, chevy 3100, chevy 350, s-10
