Old 10-29-2014, 06:05 PM   #1
Hotrob72
Hotrob72's Avatar
trouble bleeding
Ok I have a odd setup done by prior owner. Truck is a 1969 which has disc brakes on the front although still runs what looks to be the original drum/drum master (same size bowls) (has power brakes) and also looks to be the drum brake brass metering valve (2 inlets, 2 outlets, no reset on the light plug). All had been working just fine untill I swapped out the front brake hoses for new as they were pretty wore looking. Now try to bleed and the pedal just goes to the floor with no resistance. (have not touched the rear yet) I have only tried to bleed the front as thet is all I had apart. I unscrewed the line for the front brakes off the lower part of the brass metering valve and....no fluid came out. Any sugestions ? I did try opeing the front bleeders 1st to gravity bleed...nothing came out. Unscrewed the hose off back of caliper and just a couple drips. I relize the master and metering were wrong although have had truck for a couple years and it was working fine.
1971 chevy c10 ECE 4.5/6 dropped
1970 suburban ECE 4/6 Dropped 45K original miles so far
1948 Ford Sedan
1941 Dodge COE
1932 ford roadster
the rest are normal drivers
Hotrob72 is offline   Reply With Quote
Old 10-30-2014, 09:38 AM   #2
Hotrob72
Hotrob72's Avatar
Re: trouble bleeding
anyone have any thoughts, still can't get brakes bleed.
1948 Ford Sedan
1941 Dodge COE
1932 ford roadster
Old 10-30-2014, 10:33 AM   #3
oldman3
oldman3's Avatar
Not sure if there could be more problems, but I would disconnect the line at the MC and see if you have fluid, if no MC is the problem. If fluid does come out then hook it back up and go to the next fitting and again check for fluid. Will have to work your way from MC to the caliper checking at each fitting for fluid. May be some blockage somewhere. If you have a friend that has a pressure bleeder, this may take care of the problem...Jim
oldman3 is offline   Reply With Quote
Old 10-30-2014, 12:08 PM   #4
NEWFISHER
NEWFISHER's Avatar
+1. Just like electrical, start at the source ( even though it was working before, things do fail) loosen the lines and push the pedal. If no fluid-replace master. If fluid, continue down the lines individually.
GOD BLESS AMERICA!
NEWFISHER is offline   Reply With Quote
