Old 10-30-2014, 02:51 AM   #1
texjake
texjake's Avatar
Windshield washer not staying primed
My windshield washer will not stayed primed. My pump works great & my squirters are clean, but if it sits for a few hours or days it takes forever for it to get fluid back up to the squirters. It seems to have gotten worse since I shortened the supply line, I had way too much extra line coiled up inside the fender well & shortened it thinking it would get fluid up to the squirters quicker. But I guess I wrong about that. Any suggestions besides replacing the original pump with an electric pump?
"Now all I need is a shop to go with my shop vac!"
texjake is offline   Reply With Quote
Old 10-30-2014, 08:13 AM   #2
cdowns
cdowns's Avatar
Re: Windshield washer not staying primed
i'd replace the hoses with brand new tight fitting hoses
Old 10-30-2014, 09:33 AM   #3
brown7373
brown7373's Avatar
You didn't say what year, but I'll assume it is under the dash like a 72. The pump manifold that the hoses attach to go bad, even if new. The manifold has the 3 small rubber valves, and if they don't seal, the pump won't pump. Even a brand new one from the parts store may be years old and have dried out valves that don't seal. Every time I think about the pump, I grind my teeth. What a stupid place to put it.
brown7373 is offline   Reply With Quote
Old 10-30-2014, 02:30 PM   #4
texjake
texjake's Avatar
I installed all new hoses & fittings & I still have the problem.
Old 10-30-2014, 07:38 PM   #5
texjake
texjake's Avatar
Yea sorry. It's a 68' & yep, it's under the dash & I have factory A/C in my truck too. Which makes it worse to get to, to repair, replace or modify. It works great, it's that it just doesn't seem to hold fluid in the line & takes forever for it to pump it back up for it to come out the squirters. I manually have to prime it to get it to work. I like the idea of installing an electric pump under the dash near the existing pump but I just put my dash all back together and really don't feel like tearing it all apart again.
Old 10-30-2014, 09:47 PM   #6
FirstOwner69
FirstOwner69's Avatar
The easy fix might be to try a cheap check valve out of sight in the supply line between the reservoir and pump. A lot easier than getting to the pump.
Not sure this is the right size or the proper application...does say liquid in the title though.
http://www.ebay.com/itm/Hydrogen-HHO...10571a&vxp=mtr
Found this by searching ebay motors for "check valve". Lots more in various sizes including some for gas and diesel made of aluminum.
http://www.ebay.com/itm/6mm-1-4-Fuel...5f499e&vxp=mtr
FirstOwner69 is offline   Reply With Quote
Old 10-30-2014, 10:22 PM   #7
BigRed76
BigRed76's Avatar
The original pump in my '71 didn't work when I got it so I installed an electric pump under the dash, and it still looses its prime. After the truck has sat for a while and I turn it on it takes at least 5 seconds for the pump to prime the whole system. So with an electric pump it still looses its prime but you don't have to manually prime it because the electric pump is strong enough to do that.
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 10-30-2014, 11:22 PM   #8
Turbo1dr
Turbo1dr's Avatar
Yep. A cheap check valve will do the trick.
1971 Cheyenne Super - Factory Big Block - Second (1987-89) & Fourth (2014-) Owner - To be restored
1978 Turbo Malibu - Owned since 1986
1987 Grand National Aerocoupe -1 of 1
1988 LeSabre T-Type - Supercharged
Turbo1dr is offline   Reply With Quote
Old 10-30-2014, 11:40 PM   #9
texjake
texjake's Avatar
Good job! Now that's thinking outside the box. Now why didn't I think of that...lol I'm going to try that and let you know what the outcome is. Thanks!
Old 10-31-2014, 05:19 AM   #10
nzc10
nzc10's Avatar
I fitted a one way valve I got from a pet store which is used in fish tanks it was exactly the right size and was only a couple bucks!
"I ain't got no time for side tracks!"
69 R/T Charger
72 C10 Chevrolet
85 302 Jaguar
99 955 Daytona
10 1050 Speed Triple
nzc10 is offline   Reply With Quote
