Old 10-31-2014, 10:23 AM   #13
G-NUT
G-NUT's Avatar
Re: anyone with pics of a square on 24's and porterbuilt suspension at ride height
Mine is 8-lug but I've going to convert it to 5-lug by swapping the rear end and the front rotors. I have c10 spindles, ball joints, and Porterbuilt upper and lower control arms. I ordered mine through one of Porterbuilt's authorized vendors. I specified in great detail the truck I had, and what I was planning on doing and that's what I was sent. Best I can remember though, I had contacted Porterbuilt about a year ago on this topic and I think that's what they told me was that a Level 2 would be sufficient because of how the frame hangs lower below the body of the C20/30 than a 10. But I am going to cut the frame even with the pinchweld of the truck and weld in some 2x3 steel tubing inside the frame so I believe the level 3 will be necessary to achieve getting the pinchweld to the ground.
I have not installed mine yet as I only have the front. I'm saving right now to get the rear. Then I will have to save again to get my air management system. I probably won't have mine on for another year and a half or better, which stinks.
'84 Suburban C10 Silverado - laying pinchweld to the ground on 22/24.
/Porterbuilt / Accuair / Bonspeed / Landsail / Auburn Gear / Richmond Gear / Moser / Raybestos / ProMaxx / Edlebrock / Street Demon / Taylor Wire / K&N / MSD / KillMat /
SOLD: 1985 GMC Sierra Classic 2500 3+3 Crew Cab Long Bed
G-NUT is offline   Reply With Quote
