10-27-2014, 08:39 PM | #1 |
Lowering springs/ drop spindles c20
Hey guys looking to buy 5" drop springs for the rear of my 71 c20 what is the best place to get these? Cpp
Also has anyone every ran the performance online c20 drop spindles I think there the only ones who make a drop spindles for a 71 c20 thank you
1978 c20 Crewcab - Current Project 1971 c20 - Backburner IG Handle: @78bigbluecrew Last edited by c20olive; 10-27-2014 at 08:44 PM. |
10-27-2014, 08:49 PM | #2 |
Re: Lowering springs/ drop spindles c20
Here they are
1978 c20 Crewcab - Current Project 1971 c20 - Backburner IG Handle: @78bigbluecrew |
10-27-2014, 11:03 PM | #3 |
I was going to use C30 3 inch drop spindes on my C20 but went 4x4 instead. All you have to do is use C30 calipers
10-29-2014, 05:57 PM | #4 |
Here's another set for $289. I have not used them, and can't vouch for their quality or lack thereof. Just thought I'd throw it out there.
http://www.airbagit.com/spindles-ste...pi-gm7191c.htm |
10-29-2014, 06:12 PM | #5 |
Will you use your C20 as a C20 capacity truck?
If so, skip the 5" lowering springs & install airbags w/a simple schrader supply to each. You'll get the drop w/a better ride quality & still maintain the ability of the 3/4 ton.
10-29-2014, 06:13 PM | #6 |
OMG 399.99.............am I reading that right?
Measure with a yard stick Mark with Chalk Cut with a torch Built it yourself, don't count on others to to do it for you or with you. It will never get done |
10-29-2014, 06:17 PM | #7 |
C20 spindles are expensive.
I have a set of the airbaggit it ones on my 75 C20 that I got cheap used and was just using for mock up.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy Last edited by N2TRUX; 10-31-2014 at 01:56 PM. |
10-29-2014, 06:20 PM | #8 |
I have never bought 3/4 ton before...I guess they are a little more expensive...I had no idea.
10-29-2014, 06:21 PM | #9 |
That and there are very few lowering parts made specifically for the 73-87 C20's. If I could go back I would have waited for a C10 instead of hoping on the C20 I got.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
10-29-2014, 09:04 PM | #10 |
Thanks guy for the input Im really like scoti idea about bags in the rear so I could still haul with the truck just wondering the best setup for the bags I'm new at this if ya can't tell this is my first build thanks for the help
10-30-2014, 01:17 PM | #11 |
I did what scoti is suggesting, and what another member kieth suggested. Don't have a lot of miles on my truck, still working on some other stuff, but it does ride pretty well. I went with the bags from airbagit, happy enough with them, but not with the fittings. I had a hard time getting the push tube connectors to not leak, ordered the most expensive airbrake connectors and couldn't get one to stop leaking, finally found a knowledgeable guy at my local NAPA and bought the compression type fittings and no more leaks. Recommend buying or making the brackets for the top part on the frame, makes it easier to install, and just bolting the bottom to the trailing arm, this put me at pretty much exactly the right installed height. I did not measure, but would guess I got about 4 inches of drop and it sits with a slight rake. My front end is 2" drop springs (not spindles, I got a sweet deal from someone local), and I have a big block installed, so the front is heavier than stock. Follow this link to get 4 bags, http://www.airbagit.com/Default.asp I used the 2500 in the rear, based on others recommendations, have the 2600's in storage in case I ever want to change them out.
FYI, I have read where some people had negative experiences with airbagit, but mine was pretty positive, with the exception of not being able to get the fittings to stop leaking. If you just skip that and go to NAPA, I think you will be happy. |
10-30-2014, 02:44 PM | #12 |
Glad things are working out w/your set-up.
I'll go on record & recommend using board supporting vendors w/quality reputations (good parts, after sales service, & communication). While your experience w/Airbagit.com/AIM/Chassis Tech or whatever else they're calling themselves these days was good, a quick web search suggests you were an exception. We have several vendors here that are on the forums making suggestions, seeking out the needs of the community, & offering quality tech info (guys that support those of us who ask questions). I will always steer my business their direction over a mail order company just to save money. Ride Tech Way2Lo2 ProPerformance Porterbuilt No Limits TCI Scotts ksbrktracer AVS_JASON CHRIS67GMC Laidbackrecreations All these guys are supporters of this site w/good reputations. I encourage everyone to seek what you need here @ home 1st before going elsewhere. I start here & only go elsewhere if availability is the issue (gotta have the parts within a definitive time slot). Most often, their pricing is competitive w/any discount oversea's-parts joint.
10-30-2014, 07:33 PM | #13 |
Thank you fellas for the help I'll post up some pics when I get done with everything thanks again
10-31-2014, 01:02 PM | #14 |
Very good point, Scoti. I'll go on record and say that you are absolutely correct. I have bought from the vendors on this board and will continue to do so. Don't really remember why I went with these guys in this instance. Should have thought a little more about that when posting the links. I guess I just get excited that I could help someone out with my limited, learn as I go knowledge.
10-31-2014, 02:01 PM | #15 | |
