11-02-2014, 12:55 PM | #1 |
Wiper switch help for the uk
Hi
I'm restoring the wiper mechanism on my 57 GMC truck, and I have got it all running, except the rotary wiper switch and cable is beyond repair. I have looked at Brothers and LMC and others for replacements, but none of them seem to stock the part. Does anyone know where I can get one from? Steve |
11-02-2014, 01:16 PM | #2 |
Re: Wiper switch help for the uk
i gave mine away on this forum a while back otherwise i could send you mine.
i still have my factory wipers on my 58, they are electric but used the same rotary switch w/ cable when i shaved my dash i lost the spot for the rotary switch i converted the spot next to my headlight switch to wiper switch using a stock throttle or choke cable it attached to the wiper motor without any problem, i did cut the housing and cable to fit this won't help if your doing a points restoration, but may get your wipers working to get an inspection this is the spot where i made my wipers work (left of the cluster) out this much is off, in a bit is low, in all the way is off
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
11-02-2014, 01:39 PM | #3 |
Ogre
Thanks for the fast response. I like your idea, just have to live with out is off. Steve |
