Broke
4x4 Turbo 400 to NP205 adapter
Looking for an adapter to mate a np205 to th400, anyone got one for sale?
72CheyenneSuper1ton4x4BigBlock |
Young Gun wth Fast Inline
Your on the quest to the impossible. I wish you luck though, and i have made it thru the impossible too.
1967 Chevrolet LWB with built 292! 415 ft. lbs of torque, 4 speed :O with 27% overdrive too, 3.73 Posi. Frame and body done... getting painted!!! |
Broke
For some reason I alway's take the hard way!?!?!
Have you checked advanced adaptors?
400/205 adpter
Try this guy, I can't remember his name though. I order my 400/205 adapter new from him. Honest fellow, answered all my tech questions, and shipped promptly! I will do business with him again in a minute!
http://www.4xheaven.com/ BBB ![]() |
Broke
Thanks fellows. BigBlockBurris I'll give them a call, appreciate it.
his name is Vince and there in gloversville NY
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania |
I need one too. So i called the chevy dealership today. He said he can get a 1980 400 to 205 adapter for $275. Is there any differance between the years on this adapter???
Randy Dont mean to steal your thread, but this info might help you too. ![]()
WFO-- WIDE F!#@IN OPEN
a 400 is a 400 as long it should be the same
i think the spline count on the input of the 205 might have changed in the mid 80's. I dunno if this would be a problem or not.
1969 GMC K2500 ![]() 1996 Honda Accord 2007 Kawasaki KLR 650 |
Mike
Go to www.offroaddesign.com they have a write up about the differences in the 205's.The 400/205 has a bigger input shaft bearring than the 350/205.Needs to be taken apart and machined to fit the new one.Just for your info in case it is not a 400/205 case. The adapter should be the same for all 400's.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires Last edited by smokekiki; 01-22-2004 at 10:20 AM. |
Mike
Check this for the info on different 205's http://www.offroaddesign.com/NP205tech.htm
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires |
Thanks for the link smokekiki
In 84 or 85 they changed the shape and bolt pattern on the 205 case. It depends on what year your t-case is. Find out before you order because they will NOT interchange.
#15 |
![]() Join Date: Dec 1999
The 80 version will have the round pattern that bolts to the t-case. I have heard the older version refered to as the race-track bolt pattern. Just make sure you get the one you need for your t-case. I have a brand new one (race-track) that I dont need. Just want what I paid for it, was $280.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
#16 |
Vince at 4XHEAVEN said there is only one 400 to 205 adapter. I assumed it was for my 72 transfer case. Now i,m not so shure.
Can you bolt a 400 to a old style T.C.??
#17 |
What 1tonswb said is correct according to the info at Off Road Design. The race track pattern is the adapter you need. But the TH400 never came in pre 73 4x4 trucks so the t-case most likely has the male input, you will need the new input gear and bearing if you have a 72 t-case. The case will have to be machined to accept the bearing, I had mine done by a local shop for $40 after I dissasembled the unit. I can post pics of the adapter one I get my camera batteries charged.
