Old 10-11-2014, 08:16 PM   #26
PDXk5
PDXk5's Avatar
Re: Greetings
Originally Posted by DEISS View Post
Your Blazer is in amazing condition, lots of guys here are in envy, including me, of such a rust free survivor. When you get the chance would you post a pic of the options SPID on the inside of your glove box? Thanks, I'll be following along with your subtle and tasteful modifications, Jack.
Here is the SPID.
image by Luftwaffepdx, on Flickr
PDXk5 is offline   Reply With Quote
Old 10-29-2014, 11:53 PM   #27
PDXk5
PDXk5's Avatar
Re: Greetings
Originally Posted by DeadheadNM View Post
Very nice K5! Thanks for posting. I'll bet that OEM paint would really shine after a buff and wax. Check out this before/after pic of an OEM paint truck I recently had detailed: http://67-72chevytrucks.com/vboard/s...56&postcount=4
I have polished/buffed the paint. These are pics without wax. When it has wax, it really shines. The paint is a little thin on the sides where the body lines slope in but for a vehicle more than 40 years old, I think it adds a nice patina. The paint on the hood is largely gone. Significant areas of the black primer is showing through. I would like to have the hood repainted to match the rest of the truck. I know it may be hard to match but think this is the approach I want to go.
Not the best lighting conditions/photos but one can see the difference in the paint between when I first got the rig and what it is like now.
Old 10-30-2014, 08:01 PM   #28
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: Greetings
Perfect!
Old 11-03-2014, 12:06 AM   #29
PDXk5
PDXk5's Avatar
Re: Greetings
Hella H4 conversion headlights installed
I converted the headlights to an H4 type. I went with the Hella lamps as they look similar to the original 7 inch headlights and one has to really look to notice they are not stock.
After much research on 67-72chevytrucks a Forum, I purchased a wiring harness with built in fuses and relays and the lights online. The Hella lens are very nice quality - they have glass lenses and metal reflectors.
Before
After
IMAG0209 by Luftwaffepdx, on Flickr
I routed the new headlight harness along the existing wire mould along the radiator. Power comes directly off the battery. I mounted the relays on the fender near the battery.
Illumination is significantly improved over stock.
Stock - sealed beam - low beam
New Hella H4 conversion - low beam
Stock sealed beam - high beam
New Hella H4 conversion - high beam
1972, blazer, build, restomod, restoration
