01-21-2004, 02:51 PM | #1 |
pre bent brake lines
does someone make prebent brake lines and if so could someone give me a link? I need them for a 72 3/4 ton 4x4. and is the master cylender the same on a 2wd and 4wd?
69 3/4 ton 4x4 gmc with 6" sky jacker soft ride. 350 / th350 / 205 work in progress |
01-21-2004, 03:10 PM | #2 |
Resident Curmudgeon
Master cylinder is the same.
I know they make 2wd brake lines but I have not seen 4x4. Your best bet is to inquire at some of the vendors listed on our home page
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
01-21-2004, 03:27 PM | #3 |
ok thanks
01-21-2004, 09:34 PM | #4 |
I got mine from Ricks Pickupparts. He ordered them for me. I have not installed them yet. I was going to make my own but I wanted to use SS lines and I haerd you cant flare it.
1970 k10 1971 C10 Gilbert Az |
01-21-2004, 09:56 PM | #5 |
A tubing bender can be had for cheap and you just have to get a rough estimate of the length from the old lines. If you can pull them without racking them up too much you can just copy the bends in the old line and you're done.
86 Silverado C10 back to 305 power! 67 C30 Dually Dump, with 350 transplant, Rockhauler 05 Duramax 3500 "If at first you don't succeed, try a bigger hammer" Member of the 1-Ton club! |
01-22-2004, 12:24 AM | #6 |
I got SST brake lines (pre-bent) for my K20 from Chevy Duty.
'72 Chevy K20 - 383/4sp/205 - SOLD after 41 years in the family Next project - K/5 Tahoe (71 Blazer on 99 Tahoe chassis) Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=789958 |
01-22-2004, 12:48 AM | #7 |
if you are interested I have a new and unused set from Inline Tube still with the plastic things over the threads for sale for $125.plus shipping. They are for "1971 Chevy/GMC Truck 4wd Power Disc Brake 3/4 ton Longbed 10 pc stainless". They cost me $200 plus shipping and won't work with my later axle setup.
Bernie |
