10-30-2014, 12:04 AM | #1 |
Oil filter adapter issues
Is there a better type of oil filter adapter than the one from Mr. Gasket? My filter fell off today as the nipple was too far in and even though the filter seem tight, it still fell off. My engine is a 1963 283 that originally had the canister filter. Thanks
10-30-2014, 10:48 AM | #2 |
Never Ending Projects
Re: Oil filter adapter issues
You should be able to get a factory GM one from a dealer. Other option is to hit up a junk yard and remove a factory one from another engine.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
10-30-2014, 06:22 PM | #3 |
Thanks Chevy mike. I thought later models had the filter area recessed into the block and thethreaded nipple was threaded into the block? I'll check it out and see about changing out my setup
10-31-2014, 12:29 AM | #4 |
Senior Enthusiast
I had the same experience with an aftermarket adapter on a 283 back in the 70's. The adapter actually cracked and the filter fell off. I discovered the problem when the rods started knocking. I was really lucky finding a .010 under crank in good shape and a replacement set of matching bearings fixed the damage.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
10-31-2014, 08:22 AM | #5 |
That was lucky. Ayou having any issues with your gauge? Mine reads ok, at first, but when the oil gets warmed up, and I'm stopped, it reads 0, but no knocking or engine noise. When I'm driving, it reads about 40-50psi. Possibly a bad gauge?
11-01-2014, 11:53 PM | #6 |
60-66 Nut
The factory oil filter adapter/bypass will not work on the '67 and earlier small blocks to convert them to a spin on oil filter.
11-02-2014, 12:03 AM | #7 |
60-66 Nut
I've been lucky enough that I haven't had to buy one of these adapters,.I have acquired a few from early small blocks that were scrapped. So I did a quick search and came up with these results.
http://www.summitracing.com/search/p...ter%20Adapters The TansDapt pieces might be better than Mr Gasket, but not by much. Myself I would go with the one from Perma Cool.
11-02-2014, 12:32 AM | #8 |
Thanks Capnfab. Do you think JB Wild would hold the nipple in place? You also answered my curiosity about the bypass as well
11-02-2014, 01:24 AM | #9 |
60-66 Nut
I have never used JB Weld, but one of the forms of Loctite might work.
11-02-2014, 10:34 AM | #10 |
I w thinking of Loctite as well. I just want the nipple to stop moving so my filter stays on. Thanks
11-03-2014, 12:55 PM | #11 |
Guess I missed the year of the block. Doh!
