Old 11-02-2014, 11:16 AM   #1
chevy49
chevy49's Avatar
65 front window trim removal
I need to remove without damage thanks for info
chevy49 is offline   Reply With Quote
Old 11-02-2014, 04:32 PM   #2
ls60apache
Re: 65 front window trim removal
hello if the rubber is old I would just cut the rubber to remove it without damage. i have cut them from the inside,afterwards the w/s pops out easily with the trim that's fits in a channel in the rubber. good luck.
ls60apache is offline   Reply With Quote
Old 11-02-2014, 07:08 PM   #3
duallyjams
duallyjams's Avatar
I just used a utility knife to cut out the old rotten rubber windshield gasket with out any trouble.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 11-02-2014, 11:20 PM   #4
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
as they said just cut the rubber... even if you have a new gasket, it is better to waste the $40 gasket than risk breaking the windshield and/ or bending the trim.
the shop manual says to peel the gasket off the windshield frame from the inside while pushing out on the windshield. the gasket and windshield and trim will come out as a unit.
( I tried this once and wasted a good windshield)
IF you can get the gasket and windshield out of the truck, then you pull the gasket off the windshield, and then peel the trim out of the rubber.
Old 11-05-2014, 06:12 PM   #5
chevy49
chevy49's Avatar
Thanks for info
