02 Sensor Voltage via Scan When Sensor is Unplugged
Hi All,
I have an 1987 R10 5.0 with THM400 trans. The ECM appears to be working OK. I can get code 12 and I can disconnect the coolant sensor and it throws the code. My question is (when using Win ALDL) should the scan tool (more properly the ECM) be reporting/seeing any voltage if the 02 sensor is disconnected? IF the O2 sensor is unplugged, should it throw a code? Thanks in advance GA_TMAC |
Re: 02 Sensor Voltage via Scan When Sensor is Unplugged
Please help ... great forum!
#3 | |
//RF
"The Beast" 1975 Chevrolet C20 longbed 350/700R4! with 3inch body lift Dual Flowmasters Super 40's! TBI retrofit completed (2007-07-29) ![]() New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17) Last edited by rfmaster; 11-06-2014 at 01:54 AM. Reason: typo |
