Old 11-04-2014, 12:42 AM   #1
A.Bursell
67-68 Emergency Brake Cover Install
i picked up a cover for the e-brake in my 67 a while back. My truck did not originally have one but I would like to install it now. I can see where it will need to go, and how it will need two holes drilled. I would like it to look as original as possible, so I am looking for fastener info. Is it held on with self-tapping screws? Bolts and nuts? Some other type of fastener? It looks like there is not good access to the back so I am thinking something that does not require access from the rear.
Thanks in advance.
Adam
A.Bursell is offline   Reply With Quote
Old 11-04-2014, 07:05 AM   #2
71 super
71 super's Avatar
Re: 67-68 Emergency Brake Cover Install
It takes two screws just like the ones that hold the column seal at the dash bezel. They have the large flat pan head and 1/2 long or less
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 11-04-2014, 08:15 AM   #3
67JimmyMO
67JimmyMO's Avatar
Please post as pic of this if you can (anybody). I don't even know what an e-brake cover is.
1967 GMC SWB 383 Stroker w/Saginaw 4sp
1979 Chev C30 Scottsdale Flatbed 350 4sp
2000 Chev 3500 Flatbed 454 Automatic
1978 GMC 6500 Flatbed Dump 366 5sp + 2sp
1965 Chev K10 LWB 230 4sp
1985 Chev K30 Flatbed 350 4sp
67JimmyMO is offline   Reply With Quote
Old 11-04-2014, 08:40 PM   #4
A.Bursell
Pic from online:
It covers the gear mechanism of the e-brake to clean it up a little.
Old 11-04-2014, 08:44 PM   #5
A.Bursell
Can you tell me if they are self tapping or there are nuts behind them or how they install? I don't feel like there is enough room behind the lip to get anything without interfering with the cluster so I could use some help or maybe visual.
Thanks.
Old 11-04-2014, 09:46 PM   #6
71 super
71 super's Avatar
Self tapping. Let me see if I have one for you to see
Old 11-04-2014, 09:47 PM   #7
67JimmyMO
67JimmyMO's Avatar
Originally Posted by A.Bursell View Post
Pic from online:
Hey thanks for the pic, I will have to look at mine to see if it has one of those.
Don't think it does.
Old 11-05-2014, 07:49 PM   #8
A.Bursell
That would be great. I have an idea of what I need now, probably just look for the same setup as the under-column screws that will work but pictures and info would be big help.
Adam
Old 11-05-2014, 07:50 PM   #9
A.Bursell
I believe they only came on CST's. I see they are now available as reproductions for about $30. I thought it would be a nice dress-up item and was somewhat rare when I bought this some time back.
Old 11-06-2014, 01:32 AM   #10
'68 Newtricks
'68 Newtricks's Avatar
It is in deed held on by self tapping screws and a CST thing. Here's my under/over shot. Sorry about the blurriness, it is past 9 and dark out after all
'68 C10 SWB
'85 K30 Blazer
'68 Newtricks is offline   Reply With Quote
Old 11-06-2014, 02:01 AM   #11
A.Bursell
Very helpful! Thanks!
I noticed it looks like yours has bolts holding the column cover and brake cover vs. mine has screws holding the column cover. I wonder if that is a change from 67 to 68. Unless I just cant see well in the pic and they actually are screws. I think I will pull a column cover screw and try to match it up for my brake cover.
Thanks again for the help!
Adam
