Old 11-07-2014, 01:19 PM   #1
ScottH
ScottH's Avatar
Is this a stock quad shock setup?
Recently bought an 87 V10 that I am in the process of fixing up. I bought a new set of shocks to install and noticed that the front quad shocks do not appear to stock. By that I mean if u look in the LMC catalogue at the mounting brackets for quad shocks, one is mounted lower that the other. This makes sense as the replacements I got for the front one shock is longer than the other.
After looking them over on the truck I am thinking that someone just threw another set on the front at one time, squeezing it next to the original. They obviously are 2 different shocks, but do appear to be equal length.
At this point I think I would be fine with eliminating the quads and just using the standard 2 setup. I wont be lifting, plowing, or doing much off road with it.
Any info or opinions would be appreciated.
Scott
1963 C10 swb fleetside
1966 GMC G1000 Handi-bus (future project)
1955 Chevy 2 dr. wagon
ScottH is offline   Reply With Quote
Old 11-07-2014, 02:03 PM   #2
Myers horsepower
Myers horsepower's Avatar
Re: Is this a stock quad shock setup?
That looks like the Old Rancho dual shock upgrade. Factory dual shocks have different top mounts, one shock is longer than the other. I would just put a good signle shock on.
I do have factory dual shock on the front of my V3500 (big block w/winch and bumper)
1990 chevy Crewcab K30 454tbi/th400/np205twin stick/14bltFF,eaton posi/D60.
1972 CST K5 350/th350/12blt,eaton posi/D44
1970 K10 SWB
1970 K20 350/th350
Myers horsepower is offline   Reply With Quote
Old 11-07-2014, 02:16 PM   #3
400/400
I have an 87 V10 with factory quad front shocks what you have isn't the same as mine. factory set-up has two separate mounting locations on the frame.
1979 K25 350/SM465/205/44HD/14FF
1985 K20 400/400/208/10/14
1987 V10 TBI350/700R4/208/10/10
'85 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=643968
400/400 is offline   Reply With Quote
Old 11-07-2014, 03:28 PM   #4
KQQL IT
At the body shop.
KQQL IT's Avatar
Second bracket for a 4wd
Old 11-07-2014, 05:34 PM   #5
HEADTURNINGC10
my 1984 k10 has dual front shocks (truck came with a 6.2) ill post pictures when i get home today. im starting to think my is an aftermarket setup does anyone have a picture of theirs?
HEADTURNINGC10 is offline   Reply With Quote
Old 11-08-2014, 12:42 AM   #6
Your41Plague12
Your41Plague12's Avatar
My 83 had them. Yours is definitely aftermarket.
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
Old 11-08-2014, 01:20 AM   #7
ScottH
ScottH's Avatar
thanks everyone for their input, goin back to a single setup
Old 11-08-2014, 02:15 AM   #8
Ziegelsteinfaust
I got kyb gr2's on my K20 and it handles great as far as I can tell. My first 4x4, and I removed my sway bar. I got them on special from rock auto for $13 each.
I would only try a dual shock if I had large tires.
Ziegelsteinfaust is offline   Reply With Quote
Old 11-08-2014, 09:59 AM   #9
motornut
78K & 79C Jimmys
motornut's Avatar
seen in a junkyard
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
