Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Closed Thread
Old 11-08-2014, 02:15 PM   #1
jjzepplin
jjzepplin's Avatar
Re: 67-72 Chevy Truck fuel gauge diagnostics 101
OK so I go after this mutha with a vengeance and tested the new sender with my old gauge and boom she works fine. Drop the empty tank and pull the old unit. Then it hits me-new one does not have a pickup for the fuel! Sumbugger! So I modify the old pickup to use the new sender. Took a pencil torch and soldered it on. Tested and boom still working good. Then it hits me-again this whole apparatus needs to fit thru a small arse hole. Aint happenin the way I have it. So rebend the pickup and float and bend this and that and finally it goes in. I think It works as I put 2.5 gallons from a can in it and the needle moved up. I think It may register full for a couple gallons before it registers any movement but it will tell me when it's empty. Full should be at 30 gallons.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline
Old 11-08-2014, 02:23 PM   #2
TBONE1964
Cluster King
TBONE1964's Avatar
Sounds like you got it. I will be curious to know how it works when you fill it and as it runs back down to empty.
Good work JJ,
Take care,
Tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com
I am also a dealer for Counterpart for gauge cluster parts only.
Also see my facebook page, CG&C
TBONE1964 is offline
Old 11-11-2014, 11:15 AM   #3
wayno
fantastic write-up TBone.. now if I can get you to do a similar write up for TACHs lol
64 Step Side - The Mistress
wayno is offline
Old 11-11-2014, 12:27 PM   #4
jjzepplin
jjzepplin's Avatar
Oh yeah! I'm in for that too!
Old 11-14-2014, 03:04 PM   #5
TBONE1964
Cluster King
TBONE1964's Avatar
I am slowly working on getting the tools together to help me diagnose the factory tachs and figure out a way to repair them. I can currently fine tune the calibration and check function but no repair yet.
I have heard about some aftermarket kits that replace all of the insides to a modern style tachometer but allow the tach to look original.
I am always looking for ways to help people out with these things but limited to what I can invest.
I will always keep everyone updated with new developements.
Take care and have a good weekend,
Tom
Closed Thread
