Old 11-08-2014, 08:18 PM   #1
1774btcrew
1774btcrew's Avatar
REALLY need help wiring in a CS-144 alternator
Well, I had custom brackets made to install a 200 amp alternator and A/C compressor on my 4BT Cummins motor. I had a friend come by who is really good at wiring to help me sort it out. The thing is he is usually working on European stuff. This has the PLIS plug on it. I plan on running a tachometer. Wired it where the P is tachometer, L which is red going to the original red on my stock alternator, and the brown to the brown on the existing wiring. The alternator isn't showing any output. I get the information we used from Pirate4x4.com on the alternator page http://www.pirate4x4.com/tech/billav...art2/#csseries I know I still need a 50 ohm resistor put in but I am not even sure on the best place for it. I would REALLY appreciate any help possible ASAP as I am trying to get my truck completely mobile by Friday so can actually take it to the c10 show at Dino's. I have been the last 2 years and something has always been an issue that I couldn't drive my truck.
AZPartsLocators on Instagram
1972 Cheyenne Super Short Bed big block "Blackie"
1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog"
1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck.
1774btcrew is offline   Reply With Quote
Old 11-08-2014, 09:24 PM   #2
mattybilt79
Re: REALLY need help wiring in a CS-144 alternator
Get the plug adapter from parts store just got one for my 85 running a cs alternator. If your dash has a volt guage it should be an ac delco 8078 if you have a dummy light its an 8077, personally went to oreilly auto parts gave them delco part number and it crossed over to a bwd part number and got it the same day for like 14 bucks and works great.
mattybilt79 is offline   Reply With Quote
Old 11-08-2014, 10:02 PM   #3
1774btcrew
1774btcrew's Avatar
I actually got a plug when I bought the alternator. It is wiring it in that is the issue
Old 11-08-2014, 10:53 PM   #4
gmachinz
The resistor solders inline (series) on that brown wire lead. Are you positive you are getting +12V (actually 14V+ running) with the engine running?
gmachinz is offline   Reply With Quote
Old 11-08-2014, 11:15 PM   #5
1774btcrew
1774btcrew's Avatar
It isn't showing any voltage at all running. This is why I don't think it is wired correctly
Old 11-08-2014, 11:29 PM   #6
gmachinz
If you have the alternator wired as the diagram shows, did you verify you are getting 14V+ on your exciter wire from the truck? If you aren't, something is wrong in your wiring. If it is and the alternator shows no output, something is wrong with the alternator. So first verify supply voltage to I terminal, then verify voltage output.
Old 11-08-2014, 11:54 PM   #7
1774btcrew
1774btcrew's Avatar
which is the exciter wire from the truck? The brown one?
Old 11-08-2014, 11:58 PM   #8
Paul83
Paul83's Avatar
The brown one was the one on mine, but use a tester. It should only have power when the key is on.
I don't care how old or gangster you think you are; if a 3 year old hands you a play phone you answer that!
I like long walks on the beach, dinner by candle light, and poking dead things with a stick.
Paul83 is offline   Reply With Quote
Old 11-09-2014, 12:01 AM   #9
gmachinz
Yes....on its own, that wire should have 12V on it with the key in the "on" position. If not, just try using a jumper wire from the "I" alt terminal to the battery and measure output alt. voltage-you may need to run the remote sense wire to the battery too just for testing purposes. Now start the engine and verify you have over 14V coming out of the alternator. If you do, go through your existing wiring by tracing the brown lead. If you don't, then that alternator has an issue. It can be tested at a parts store just like any other CS type alternator.
Old 11-09-2014, 12:07 AM   #10
1774btcrew
1774btcrew's Avatar
Thanks, I will do some more checking in the morning when it is light.
Old 11-09-2014, 04:47 PM   #11
mattybilt79
You said you bought a resistor but had not wired it in yet? As far as I know without the resistor inline it will not charge at all and from what I have read will damage the alternator. The adapter plug I got has the resistor about an inch from the plug coming off the apt. I swapped an 87 motor in my 85 and that was all it took to get it to charge. Make sure your running an 8 guage wire minimum from the post on the alt directly to the pos side of your battery.
Old 11-09-2014, 04:55 PM   #12
mattybilt79
Sorry went and looked at the pigtail again the resistor is about 5 inches away and the total length plug to plug is about 10 inches.
Old 11-09-2014, 09:00 PM   #13
1774btcrew
1774btcrew's Avatar
Thanks for the picture. Where did you get your adapter plug?
Old 11-10-2014, 12:26 AM   #14
mattybilt79
Got mine at O'Reilly auto parts, gave them the ac delco part number and it cross referenced to a bwd number that they carry. Auto zone had a cross ref number for it too.
Old 11-12-2014, 10:15 PM   #15
1774btcrew
1774btcrew's Avatar
Still can't get this sorted. I went and had the alternator tested and it passed. It shouldn't be an issue with the existing wiring as the previous stock alternator always worked with no issues.
Old 11-12-2014, 10:15 PM   #16
1774btcrew
1774btcrew's Avatar
Where in AZ are you?
Old 11-12-2014, 11:24 PM   #17
Just call me Sean
Just call me Sean's Avatar
On some vehicles if the charge bulb is blown the alternator won't charge. Voltage for the brown wire passes through it.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 11-13-2014, 11:57 PM   #18
1774btcrew
1774btcrew's Avatar
Thanks for everyone's input/help. Worked a big part of the day on it to no avail. Had some other no related wiring that needed soldered in and cleaned up. Hopefully tomorrow is a better day!
Old 11-14-2014, 12:18 PM   #19
hatzie
Moderator
hatzie's Avatar
Did you get an adapter with a plug and socket??? Or are you trying to roll your own with a pigtail that has one plug?
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 11-14-2014, 01:51 PM   #20
1774btcrew
1774btcrew's Avatar
I did my own since I wanted a tachometer. I used a 5W 47 Ohm resistor soldered into the L wire.
Old 11-15-2014, 12:28 PM   #21
hatzie
Moderator
hatzie's Avatar
Assuming this is the 1977... Download the 1977 wiring diagram from the RTFM link in my signature.
The SI alternator has 2 terminals on the plug.
  • Terminal 1 Brown wire {16BRN 25(SXL)} is the Field Exciter wire from the ignition switch through a resistance wire or the warning lamp.
  • Terminal 2 Red wire {12RED 2G(SXL)} is the remote sense wire that goes back to a fusible link at the firewall J stud. The starter on 80's models.
Do you have a CS130 with a P L I S marked socket or P L F S ?
If you have a P L I S socket on your CS130 alternator...
  • Terminal "S" is the remote sense connection. This should hook to Terminal 2 {12RED 2G(SXL)} from the Delco SI plug.
  • Terminal "I" is the Field Exciter connection. Terminal "I" has an internal resistor. This should hook directly to Terminal 1 {16BRN 25(SXL)} from the Delco SI plug.
If you have a P L F S socket on your CS130 alternator...
  • Terminal "L" is the Field Exciter and warning lamp connection. This should hook through a resistor to Terminal 1 {16BRN 25(SXL)} from the Delco SI plug.
Old 11-17-2014, 10:36 PM   #22
1774btcrew
1774btcrew's Avatar
So the current situation is, I have found the problem. The brown and white wire(exciter) was broken right at the ignition switch. I decided I would cut the wire and solder it back together. I had initially planned on just running a new wire. There was plenty of brown wire to just pull up. Silver solder wouldn't even stick so against my better judgement, I just crimped the wire and so far everything is working.
Old 11-17-2014, 10:39 PM   #23
gmachinz
Good to hear Jeff! I figured if you had it charging by jumpering it, then it had to be between the alt and dash-good job tracking it down.
Old 11-17-2014, 10:46 PM   #24
1774btcrew
1774btcrew's Avatar
Thanks! It is a relief for sure! Just ridiculous that the wire was broken. I hadn't even been working under the dash at all. It seems the brake pedal was grabbing it and it was just a coincidence that it happened at the same time as I was putting a new alternator in. I just have to get the tachometer to work with the diesel now!
Old 11-17-2014, 11:06 PM   #25
gmachinz
Hey BTW, sorry if you tried calling the other day-I was in BFE Iowa picking up a couple rust free boxes and had no signal all damn day.....I got within range and my phone went crazy with missed calls and messages! Lol
