Re: crossmember nightmare. help?
I have the same side mount crossmember as you.
I mounted mine just high enough to give me 1/2" of clearance between the pulley and the original crossmember. The engine is tilted 3.5 degrees down in relation to the frame and that worked out perfect for clearances everywhere. I matched that tilt with 3.5 degrees up at the pinion. |
polishing a turd
what kind of rear suspension? if it is leaf springs, you may want aim that down a degree or two from where you have it
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512 53 buick special - straight 8 sled - blow through turbo 47 gmc - flatbed hot rod build 99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van' |
