Old 11-11-2014, 02:13 PM   #1
hdff
hdff's Avatar
Steering gear box question
Hi all. I need to replace my steering gear box due to a seal leak. My question is is the quick ratio gear the way to go? I do not have a stock big steering wheel, mine is an after market about 13 1/2" across. I could understand a quick ratio with a big stock wheel. Can anyone that has replaced theirs tell me some pros and cons and which you went with and why. I will be replacing the gear box on a '71 short bed with a 402BB. Thanks in advance for all of the great info I get from this site!!
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach
"Wanda"
Don't argue with idiots, People watching may not be able to tell the difference...
There's someone in my head........But it's not me......
cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394
hdff is offline   Reply With Quote
Old 11-11-2014, 02:30 PM   #2
EdSevered
EdSevered's Avatar
Re: Steering gear box question
I was just reading up here on that very same topic last night. Here's a couple of links for you:
http://67-72chevytrucks.com/vboard/s...d.php?t=549115
http://67-72chevytrucks.com/vboard/s...d.php?t=629148
Good Luck. -Ed
EdSevered is offline   Reply With Quote
Old 11-11-2014, 03:06 PM   #3
davepl
davepl's Avatar
OMG yes. When I pulled mine out of the shop the first time I though the rag joint must be off, because you had to spin the wheel like a wildman to get anything done.
Plus, it's hugely over-assisted and the steering wheel enormous. I wouldn't change the wheel because I want a stock look, but if I had it to do over again I'd definitely do a faster ratio.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 11-11-2014, 03:42 PM   #4
sprint_9
sprint_9's Avatar
I looked into this as well and if I remember correctly, a stock box is 4 turns lock to lock, quicker ratio drops it down to 3. Gets it up to more modern standards with the 3 turn.
sprint_9 is offline   Reply With Quote
