Re: 82 stepped retired farm truck
Have a question for Just Call Me Sean, would the the axle shafts swap from the 10 bolt in my c10 to the camaro thus eliminating the bolt pattern issue?
#2 | |
I'm just glad to be here!
The Camaro axle is a 28 spline and 30-1/16" long. The truck 10 bolt is also 28 spline, but the length is 31-5/16". That makes the Camaro axle to short... See this site for info: http://www.yukongear.com/PartsList.a...ar+(Both+Sides) I know that Travis at ProPerformance can order Moser replacement axles with the 5 on 4.75" bolt pattern and the proper center hub diameter for about $260 a set. The '95 rear end is wider overall than the existing one in your '82.
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square Last edited by aggie91; 11-13-2014 at 10:49 AM. Reason: added about the '95 rear end. |
