Old 11-14-2014, 01:31 PM   #1
jayoldschool
Moderator
Need help removing AC mounting bolts on 95
I'm tearing the FEAD off a 95 5.7 parts truck to use on one of my early V belt cars. It's an R4 compressor. How do you get the three long mounting bolts past the AC clutch?
jayoldschool is offline   Reply With Quote
Old 11-14-2014, 02:06 PM   #2
lester622
Re: Need help removing AC mounting bolts on 95
If you look at the bolts closely there is a flat spot on each one of the heads of the bolts. Make sure the flat side is facing the clutch and pull them out
lester622 is offline   Reply With Quote
Old 11-14-2014, 02:29 PM   #3
jayoldschool
Moderator
I guess I should plug in my shop light! Thanks.
Old 11-14-2014, 03:36 PM   #4
lester622
Its hard to see if you don't know that its made like that.
